1 - 8 of 8 Posts
Hello I was wondering if anyone knows the weight of a Groundskeeper cab with the doors off? Also how do you go about lifting it off? I am having trouble lifting it high enough to clear the steering column, my pulley hooked to the barn rafters will not allow it to lift high enough. Would two people be able to lift it and get it over the steering column? Any suggestions would be greatly appreciated. Thanks in advance!
The GK manual section on the cab is not very specific, but it seems to imply that the cab should be tipped towards the back of the tractor to get it off, not lifted straight up.
If you are trying to do this by yourself, have you considered unbolting the engine cover and removing it to get it out of the way? I did taken a cab off my parts tractor to sell it to Sam's Bolens, but the tractor was outside, and with the doors off, the two of us were able to get the cab off without too much drama.
Discussion Starter · #5 ·
Thanks for the suggestion, its just me and the misses out here in the woods and she's five foot flat and 98 lbs soakin wet! But we will give it a go, she can surprise me sometimes. The bigger issue is me, I tore all the ligaments in both shoulders and have over eighty percent damage to both rotator cuffs from a fall off a helo in the Navy! We will make do and I appreciate the help.
Discussion Starter · #6 ·
Rigged up some military cargo straps to a block and tackle and screwed a j bolt into a high 2x8 roof joist. Now I have the room to lift but will have to give it a go tomorrow as I am a bit gassed tonight! The wife says she will help to guide it so now the only question is to tie it to the three wheeler or go it cave man style. Let ya know how it turns out tomorrow!
Several years ago I bought an old overhead wagon hoist at an auction for $5. This is they type with the A frame side legs and a double angle iron across the top between the two legs. Bolted a short chain together and hook the chain hoist in that. Sitting right in front of the shop door outside. Not sure it would be high enough for what you need but for $5 I would not be without it. Use it to lift anything heavy I can get a chain on or a bar through. LF.JPG Not the best photo but you can see it in the background behind the trailer at the shop door. It is a good 10' from ground to the cross iron on top.
1 - 8 of 8 Posts
