1 - 5 of 5 Posts
I have a tiller for my bolens ht20 I hooked it up today for the first time and as im tilling it bounces and the driveshaft hits the axle I was wondering if anyone else has had this happen and how I could fix it so it doesn't wear a hole in the axle. Any help would be greatly appreciated.
I don't have one, but I remember someone else having a problem like that. I know that if you are trying to till new ground with out plowing 1st this can happen, Also If you are in to high a gear. I'm sure some of the Bolens Experts will be on soon. Good luck with it.
Premium Member
Did you put both pins in?
There is two pins a lower and a uper the lower one is for the tiller to sit on and the uper pin is to stop the tiller from bounceing into the axel.
  • Like
Reactions: speedyg
1 - 5 of 5 Posts
