1 - 6 of 6 Posts
Evening everyone. do any of you know where I can purchase a hydraulic lift cylinder for my old Bolens? Love that old tractor but I was plowing snow with it today and noticed that it had a bad leak. Fluid was streaming out around the shaft(rod) on the cylinder. Is there something else that I can adapt to fit
. Would appreciate any info on this subject. Thanks, Mike
Keep in mind that these tractors are built in the 70's when it was made to be fixed not replaced if you remove the fittings you can take apart the cylinder and replace the Seals (actually orings) to replace the oring for the shaft you remove the front fitting and pull on the rod after it comes out clamp a Vise grip Close to the Piston and use a 3/4 wrench to remove the Shackle (mounts on to the rock shaft) pull the rod out use a Small flat head screw drive and catch the edge of the old oring and pull it out go to a auto parts store and the Should be able to match something up my H14 I got from the scrap yard had the cylinder extended its all pitted but with over sized oring it does not leak all that bad Best of luck
Ty
Discussion Starter · #3 ·
Thank you Ty. I will try this. I was hoping that it could be repaired but it didn't appear to be repairable.
They can be taken apart.
I rebuilt the cylinder on my 1050, there's only a few o-rings in there that are alot cheaper than finding a new assembly!
If you need help taking it apart let us know and we'll direct you the best we can
Discussion Starter · #5 ·
Ty
Hello Ty, I did as you said and it worked like a charm. Got it all back together and blew a hose. Replaced two hoses that were original and it is working fine now. I did lose a U-joint last night but fixed that this a.m.. More snow tomorrow. Thanks for your help.
Discussion Starter · #6 ·
If you need help taking it apart let us know and we'll direct you the best we can :thumbs:
Wanted to thank you for your input. You are all a great bunch of people.
1 - 6 of 6 Posts
