1 - 9 of 9 Posts
I currently have what is left of a Bolens 1250 that I used for parts. Basically it's just a frame, transaxle and sheet metal. I've tried selling it cheap but had no luck and I can bring my self to scrap it. I also have a Briggs opposed twin engine sitting around that I'm thinking about putting in the tractor. Here is where I need some help. Has anyone ever done a repower like this and if so what is involved? I know I will need to make a mounting plate for the engine and the wiring will be different. I'm not sure if I'll need to notch the frame though. I added a picture of the tractor I'm thinking about using for this project. Any and all input is welcome. Thanks in advance.
Discussion Starter · #3 ·
The engine is an 18hp twin that came out of a Craftsman GT6000 tractor.
Premium Member
Search repower you should come up with some threads with good tips and ideas. If I would of know it was for sale I would of grabed it when I was down by you.
  • Like
Reactions: farmerall
Discussion Starter · #5 ·
I had it for sale for a long time on here, and to be honest there isn't much left worth restoring the tractor, just enough that I maybe able to make it drivable. If you would have stopped here you probably would have left with a nice 853 too lol.
Premium Member
The truck was aready full with a 1962 Ride A matic I would of had to pull the trailer.
Fixer of Broken junk
Opposed twin briggs are basically the same shape and size as a Kohler or an Onan twins.I would say yes you will have to notch the frame.Notch it Like the 1886 HT18 HT20 and HT23.
Tricky thing will be trying to adapt the driveshaft to the flywheel.Other than having to notch the frame and come up with an adapter it should bolt right up in the frame.
Sawzall and a grinder are your friends lol.Hey it's better to make something usefull out of it then to scrap it.Maybe make a hitch for it and use it for plowing or just to tow stuff around with.
Discussion Starter · #8 ·
I won't need to worry about the crank adapter because I have no plans of ever using the pto on this tractor again. I'm hoping that the driveshaft and crankshaft are the same size though.
This will probably just be used to pull stuff around but I'm also going to use it as a mudder and something to just play around on.
old member
My friend put one of those in his 1476 with FEL. He had to modify the pan for driveshaft clearance. This machine works great!
[sharedmedia=gallery:albums:428]
1 - 9 of 9 Posts
