1 - 4 of 4 Posts
I tried a search but maybe im not wording it correctly. will the rear fender deck from a 1886 interchange with an HT20?
Got Sum
It will, the slot for the hydro engagement of the 1886 isn't needed on the 20 and you'll need a hole in the fender pan for the HT20 rear end dip stick, make that modification and patch the lever slot if it's an issue and you are good to go.
Premium Member
The fenders for the 1886s-05 and 1886s-06 are the same as the HT20 fenders. The fender for the 1886-04 has the same slotted seat mount as the HT20 but don't have the hole for the dip stick on the HT20. The fenders for the 1886-01-1886-03 has the older leaf spring seat mount on them and dont have the hole for the dip stick also. All the fenders on the 1886-01-1886-04 has the slot for the P-N-R lever that is not on the HT20. So in other words yes they will fit but depending on what modal 1886 it came off from it will be a little different.
1 - 4 of 4 Posts
