1 - 12 of 12 Posts
A Little Off Plumb
PDF is missing. Why don't you put this in the Articles Tech section of the Home page?
A Little Off Plumb
Discussion Starter · #4 ·
The pdf should be back now - I had a misprint in the title and had to edit it. I thought it would be best to put it in the Bolens section - my apologies.
No apologies needed. Doc has several articles in there. Most folks never look in there! If we get more articles and let folks know about them, maybe they will read them!
Very good article. There was a listing on CL out of the Sioux City area for a repaired gear for $180. Send him the gear and $180 and in two weeks you get your repaired gear back. He sent them off to a place in Indiana. I have a local welding shop run by two brothers. One brother builds ARCA race car chassis so they know what they are doing. I may have them repair an old ground up gear for me to have an extra for my two Bolens 6 speeds.
  • Like
Reactions: 29 Chev
A Little Off Plumb
Discussion Starter · #8 ·
I tried to post it in the tech section this evening but did not have success - guess I am still computer challenged.
I had a cluster gear in my 212 that lost two teeth
I took it to a friend that welding a beads to replace the lost teeth
I took it home a ground each tooth back to the shape of the old tooth
it been it my 212 for the last 3 years and have not had a problem
I hit the approve button, but the PDF is not there!
A Little Off Plumb
1 - 12 of 12 Posts
