1 - 3 of 3 Posts
Are there a lot of differant size U-joints for the bolens tractors ?? My local dis. is trying to sell me 1" cup diameter u-joints where I saw one with a .996 diameter.. Now I know that is only 4 thou,,But correct IS correct..I've been looking at all the manuals you good people have listed in GTT but can't find any sizes of U-joints.. I have a 1477 husky large frame.. And the only PT # I could find is 1724401... Is that for all Joints on all the shafts for most bolens ?? My local dis. looked at that # and shrugged his shoulders and got out a caliper.. Doe's anyone have the EXACT measurments of a 1724401--( if that is standard ) and post it ?? ALSO-- What doe's the 6N,, or 6LN,, N10,, or some of the other #'s I see stamped on universals.. Is there a chart that tells you a size by that ##..?
Thanks sodi..
Thanks sodi..
alot of shaft sizes have a max and min bore or shaft size also is it the splined end or what does it go with a tiller i know the bolens stuff it 3/4 x7/8 sq then goes to 3/4 round but your working with LG frames so i think its 13 spline and it goes to 1" round i would just pick up some 1'' round by 3/4 sq u joints and then get some square stock that is 7/8x3/4 then get it milled at a machine shop to 3/4 x 3/4 then sticker in the joint weld it up and bob is your uncle brother and sister
1 - 3 of 3 Posts
