1 - 8 of 8 Posts
Got this for too much. $40. Has steer link I needed, couple tie rods, 3 pto's, one with good u-joint. Rest is pedal, foot boards and spacers. Stuff that don't go bad or is neede, heh!
Sha-wing!!!!!
Great score;)
I have a Bolens 1456.. I took off the grass cutter which has a sq. Quad Male Shaft. My intent was to use my Bolens 18090 tiller which has a female hex shaft.
The universal connected to the H14 of course has a female quad u joint. I cannot get the u joint off to see if the PTO shaft is a hex female. If it is, will this connect directly to the tiller. If not is there a part or parts that I am missing? Do I need to get the u joint off or is there a missing part that allows the male hex shaft to connect to the female quad connector currently on the H14 shaft. Your help would be much appreciated. Fred James 603-5680433 cell#. [email protected]
Discussion Starter · #7 ·
My pto shaft is splined. The joint is PINNED on and not the quick-connect kind like my bigger tractor has. The square end is really Rectangular, little bigger one way from other. I would say if you have hex, a diff joint is needed or attachment is for a totally diff model that takes that shaft then. I'm no Bolens expert, but this is what I have found on my G14.
1 - 8 of 8 Posts
