I got this from a friend a couple years ago and just stored it until now. Both tires are cracked only one holds air. I’m going to search for a couple of used ones. It’s got a few dents to straighten out and a little surface rust nothing major. This is an 18 cubic feet model the label on the tongue says the 10 will hold 1200lbs. The part that describes the 18 model has been torn off. It has a one inch axle and really built very solid. I was going to pull the axle but it’s in there to stay. I squirted some atf/acetone down the axle seem where it meets the trailer to cover any rust I can’t reach. The tilt latch was rusted to where it didn’t spring back when I let it go. It’s fine now after cleaning and oiling it a little.
