1 - 20 of 22 Posts
Had an eventful time trying to mow today, first broke the belt that engages the cutting deck, went and got a new one, then the engine died like it ran out of gas. Took out an inline fuel filter that had been in there since I got it thinking that there isn't enough head pressure from the gas tank to force the gas thru an old filter. It started fine, drove it out into the yard and soon as I engaged the deck it died again. Tried to start it and it cranked over then the starter disengaged and just kept spinning like the starter drive went bad. Not quite the case, dang it! The starter shaft broke off flush with the starter housing. No time to try to fix that so I had to pull my old Murray out of the shed which hadn't been run in 2 years and finish mowing with it. Broke the brake spring on that and one of the cutting deck rods, which I had to weld to get the cutting deck back into a position where the drive belt would not slip. Went ahead and finished mowing without a brake tho!
I guess it's time to hunt for a starter!---LOL!! Seems like I read somewhere them things are pretty expensive, but I haven't had time to do any online research yet. I came here to lick my wounds first.
Anyone have any affordable ideas? Any help will be appreciated.
Here's some pics.
  • Like
Reactions: IamSherwood
Electric Tractors
Sounds like you had a Murphy's law day.
If you can find the engine pulley off of a starter/generator engine you could bolt it on yours and use it as a pull start, has a grove in it so you can wind a rope on.
Motor vehicle Grass Gas Cylinder Machine
I've got an extra starter/generator and pulley but it's for a Briggs, not a HH120 Tecumseh! Could it be adapted, yeah but right in the middle of grass growin' an inch a day, I probably can't fab it up fast enuff without takin a week off worK---LOL. Oh well that old Murray is still useable---I guess---
Check with the Site Sponsors, the Teccy engines used the same starter in most situations foe the 10 & 12's at least.
You should be able to track one down that came out of a Sears Roper, or a MF...
If not, you may be able to have that shaft rewelded and ground smooth again? IDK
If you go searching on ebay (or anywhere, for that matter) you will want to count the # of teeth as I think there were at least 2 different sizes.
I never seen a starter break like that before. I searched Tecumseh starters on ebay & they are a lot of them....not too bad. Most are around $60. & some less too. Hope you find one.
  • Like
Reactions: MFDAC and MH81
Banned
I'd buy a old one that needed rebuilt before I bought one off the new ones, pretty cheesy until you spend over 75.00
Collector of Rusty Junk
When I worked at the Rock Quarry, we had a few starts go bad after getting them rebuilt. They would work fine the first time, but then nothing. I would take the starter off, and the drive was out just a little bit, I would tap it back, it would fine one time and the drive would be stuck again. Turns out the shaft in the armature was twisting. We had several of these do this, they all came from the same rebuilder.
Mower Extraordinaire
I have a tecumseh starter in my building that I will let go for shipping. It's a brand new starter but I believe I got it to hot one time when trying to get the motor started. I scraped the motor and kept the starter(?).
If interested I can send you some pictures and if really interested give me a zip code and I'll see what shipping will cost.
I did hook a jumper box to it and it did spin.
Discussion Starter · #12 ·
Great advice!
I was thinking more around $100 + ship so that is considerably better.
Yeah I suppose cheaper means cheap.
I think this may be the original starter on this tractor, so it is just more like 38 years why it probably broke!
Park it at the top of a hill!! :say_what:
:bigrofl:
LOL! Here's a pic of the biggest hill in my yard! I call it "Little Round Top".
I've had good luck with these. Good people to deal with too.
http://www.mfgsupply.com/smallengine/smengstarter/smengstartertec/stc0005.html
I will sure check with them if needed, Will!
SearsYellow, that is too generous of an offer but I will certainly take you up on it! This is greatly appreciated! It appears to be the same starter. My zip code is 57703.
Thanks again everyone! What a great site!
First pic is "Little Round Top"
Then my starter.
  • Like
I will take it to post office in the morning and see how much it will be. Im pretty sure it will be somewhere between 8-15 bucks. It's something I wouldn't want to sell someone for full price because I can't promise functionality. The motor that the starter was on kept blowing head gasket. I finally got tired of messing around with the engine and junked it and replaced it with a predator 420. The day I junked the motor I got the starter extremely hot because I had to kept trying to start it.
MFDAC, I may have missed it, or I may have forgotten that I've
already seen it, but I just noticed, in your signature, you list a MF8E.
Is there a picture we can see of it?
Sorry to get off topic, but .......it's an executive....!!!
Discussion Starter · #15 ·
Man, that is real reasonable, let me know how you want payment and my address! I can't thank you enuff! I may be able to build one good one out of the two so we will see!
That's fine Will, no hijack taken! I am registered and was one of the first to post in that MF8E thread,we have talked before. Sorry I don't post more but there isn't much exciting to talk about with my tractors. I push snow with the 8E and mow grass with the 12G. I do have a snow thrower and blade for the 12G too. Here's some pics of the 8E.
Later---DAC
Discussion Starter · #17 ·
With hills like that it could probably be done!-LOL
Sorry man i didn't get by the Post Office today I got tied up buying chemicals for the grapes today. It's grape growing season and I have not even sprayed the first time this year.
I figured it was time to get my rear in gear.
Discussion Starter · #20 ·
Thanks MFDAC.
Now I remember.
I recognize the hydraulic pump/valve set up.
Glad to see it's still doing it's job.
I wish that it still had the original engine but that is long gone. That's a 10 HP Tecumseh on it now, after I tired out a B/S 8 horse about 5 years ago. Been using it for dirt and snow work for a couple decades. Never knew anyone liked them 'till mid 2011 when I found this site!
You gotta take care of business first! Whenever you can get to it is ok, the old Murray will get it done till then. It sure looks like exactly what I need! Thanks again!
Later---DAC
1 - 20 of 22 Posts
