1 - 9 of 9 Posts
hey all, I have a broken seat spring on my sulky ( think that's what its called),..... the flat bar from the seat to the lower portion of it....does anyone know if this is able to be welded ? im thinking it is probably made of spring steel which I believe is problematic due to the affects of welding on the carbon content of the steel....anyone ever had one of these welded before and if so how did it hold up ? would prefer replacing it but im sure finding just that part of the sulky would be rather difficult these days ...thanks for any input.....
Never welded one but have bent them to make shorter
If you don't mind the look, you could bolt back together with metal plate bolted on to make it one piece again till you find a replacement
These springs were also used on lots of horse drawn equipment, should be able to find one at a old engine swap meet
If you know anyone into horses they may have a old seat spring around the farm
Got Sum
You are correct, the weld even if it looks like it's good and holds ,it will fail, welding spring steel causes de-carbonization of the spring steel making it brittle. The tempering process cannot be effectively recreated in the weld, to much heat to soon in a small area, if your piece is indeed spring steel it will need to be replaced.
Any old school spring shop can make you one, if not, get on line and look for the guys in the cottage industry. I know a few guys that can do work similar to what you need. problem is distance and size. The oven needed to treat a spring like that is bigger than the guys I know are using.
There may also be a company somewhere that sells resto parts for stuff like that.
Could you post a picture and some sizes for what your looking for ? It might give someone another idea
A shop that makes truck springs can do it for you. I have no idea what the cost would be though. I live in R.I. and there is a place in providence that has been making springs since the horse and buggy days. Palmer springs is their name. Look in your local phone book for spring shops.
Other than that swap meets are another option.
Discussion Starter · #9 ·
thanks for the info on palmer springs...I checked out there website and they can definitely do it....I don't have any shops like that in my area,the places that do springs around here re bend leaf springs but from the few I talked to are not capable of making what I need which is basically a flat piece of spring steel bent at opposing 45 degree angles on each end......I was told they needed to be put in a oven ...anyhow, I think ill give them a call a see what kind of estimate they'll give me ....I could find another sulky for $100 - 150 bucks if I wanted to , but if can get this spring made for the same price range or under ill try and save it ...thanks again for everyones input ......! :wave:
1 - 9 of 9 Posts
