I picked up a rideamatic about a year ago. Got rather cheap, carb was overfilling and dumping out of the air cleaner. it's a K 161 and had a Chinese carb. Turns out the float was full of gas. Bought another Chinese carb and was fine and ran good. Yesterday the tractor was sitting for a few minutes after shutting off and gas started coming out of the air cleaner again. I suspect the same issue.
What are the best options? Find an OEM and rebuild or try another Chinese carb? These are plastic floats, im wondering if the parts are interchangeable. I know I can get brass floats for OEM carbs, not sure if it will work on the Chinese carb? I just don't like buying used carbs online as you don't know if they are complete so I keep leaning towards the Chinese replacement. Is there better Chinese carbs available?
Sent from my Pixel 3 using Tapatalk
