1 - 6 of 6 Posts
Ive had a Cozy Cab for a few years now and it was originally mounted to my 1250 by running bolts right through the fenders. Id like to get this on my Ht20 with blower this year now that i have 500+ feet of driveway to maintain. What are the factory brackets supposed to look like?
  • Like
Reactions: Sawdust
Deceased
don't quote me on this but I just put a COZY CAB on my 1050 but that's a tube frame, I took it off the tractor it was on and it had no mounting brackets or anything. in the frame of the cab had holes where they bolt to the foot peg, 2 more near the rear corners of the fender pan witch I thought they could had done better but anyway the only 2 extra pieces I got were 2 filler panels one by the clutch pedal and the other i forgot but I ill get it...now I also have the same cab as you because I was looking for one then you got one well I went to Ohio to get mine along with a trailer full but this cab I never seen mounted but if i'm right theres 3 piece, 1 kinda flat piece that goes under the seat the you bolt holes if there not there but I think there is and 2 more pieces that are mounted under the bottom the door to the frame work and I think they mount to the fender pan... I hope this helps you anf if I can help more feel free to ask. if I am wrong I will need mounting the other cab on the 1250.. good luck
  • Like
Reactions: Sawdust
Here are a couple of pics I found on mounting of these Cozy Cabs.
Discussion Starter · #4 ·
Mine was bolted to the fender also. Not a fan
Bob's Lawn and Garden LLC
Here is a couple pics of the brackets I made for mine. There is only 2 bolts that keep it on. They are in the front down at the foot rests with a rubber mount behind the bracket so not to rub the fender pan. The rear brackets are there just to support the weight of the cab.
Deceased
1 - 6 of 6 Posts
