1 - 7 of 7 Posts
Premium Member
My Wisconsin TRA-10d is always leaking oil out the breather. I've taken the cover off and taken the "reed" out but Im not sure how the crankcase vent works? How can I keep oil from running out the engine.
tinkerer
Unfortunately, the piston rings are probably starting to wear down and you are getting blow-by.
This creates more pressure in the crankcase than normal and pushes oil out thru the vent.
  • Like
Reactions: Bolens 1000
Premium Member
Discussion Starter · #4 ·
Yes the reed is in there. I will take it apart again and check the drain hole one more time. Thanks guys
1 - 7 of 7 Posts
