1 - 2 of 2 Posts
Fixer of Broken junk
I thought all 169s came with Hydro lift as standard.On the 129 and 149 Hydro lift was optional and you could get electric lift but Hydro lift was cheaper and stronger.I've seen a couple on Wide frame CC with standard transaxles but none on a Hydro.
Being that only 4,005 169s were made I would Definitely restore that one.
Wide frame Electric lift will not work on a narrow frame.The mounts,rod ends and overall diameter of the rod are completely different.
This is a Wide frame electric lift.
Yellow Cylinder Pipe Metal Gas
Here is a narrow frame electric lift.
Yellow Cylinder Gas Composite material Engineering
1 - 2 of 2 Posts
