241 - 260 of 262 Posts
All you want is just the 2 lift arm blanks the upper rocker shaft has welded to it and the 2 center link brackets with all the holes correct? No cross shafts ? $75 plus shipping all the holes will be drilled in the arm blanks too.
I will take a pic. Of what you will get so stay tuned.
Yes. I'd also like to purchase the small shafts that weld to the upper arms as well as the shaft that welds to the 2 center link brackets, the piece that connects to the right side lift arm and mounts to the arm going to the lift cylinder would be great too., just the blank, I'll weld.
OK , the lift tab and lift link are easy, the main shaft and parts that attach are keyed and pinned to it for assembly and service reasons. The small top shaft is basically just a pin that holds the center link mount from flopping around . there is a boss that the plates mount to that rides on the main rocker shaft .the plates are retained with snap rings.
Do you have the ability to machine a key slot in a collar and one arm (broaching)? Only one arm welds on to this shaft. The side that does the lifting is the side that is keyed and pinned. I just made one up but has not been keyed yet. I do this on a wire edm so it comes out perfectly aligned with the lift arms centerline. I'll snap a few shots later to show these pieces when i get to work. On the second shift this week TGIF!!
These parts are the ones that require the most attention for proper operation. Well except the pto side, that side is WAY HARD with out fixtures . also the factory bracket has no provision for the shaft to pass through .
I have a friend that has a mill so I think I can make a key, or can buy a shaft that's keyed on one end. Did you use 1" for the main rockshaft or 1 1/8"? What was the price again for bare bones kit, nothing welded, no hardware, no paint?
OKtthis is a photo of the original proto- type brackets that are factory with the exception of the modified pto side.
The main shaft is 1.125 just like factory. If you can modify your stock pto side braket as in the second pic of the back side then it will work for you.
There is no way I can sell just the pieces for the pto bracket. It is very tough to assemble with a fixture. The entireupper assembly ready to bolt on would be $250 or $210 with out thw right side. You can use yours as long as it has the lower holes drilled and bushed. If your brackets were for a tillwr kit thwn they are not done only thr top are used and they are in the wrong location for any 3 point components.
  • Like
Reactions: Firemang
Ok, so entire upper assembly minus paint and hardware $250 (very fair price) and the lower arms minus the balls, linkage hardware, and paint?
The lower arms with out the balls welded on, machined are $45 each . mostly material cost , that stuff is $$$$ as I use a strong grade of steel with specific grain structure, not that its needed but gives me piece of mind.
Ok, so I'm looking at $340 total, plus shipping to Oregon which is probably around $50 with the weight. Message me your address and whatnot and let me know what you think it'll cost to ship. I'll put some $ together over the next couple of paychecks and send you a money order, versus a check.
Sky does this come with the eyes just not welded on?? Or no eyes at all??
These are just the arms machined, no weld on ball ends and the arms are basically straight. as my hitch design doesnt use the dog leg arms . i have found that they dont behave anyware near as nice as the straight ones do.
OK a few shots of my 3 point on my diesel LGT 165 with the updated draft arms (lower implement arms) and lift links and my grader blade I just made fit my drawbar frame. It works pretty slick too. Enjoy
I need to update this thread, the latest design, pictured is working flawlessly! No issues and even have the factory pto running smooth as silk. It's a very functional unit for sure !. Only thing iI need to now is make up a 540 pto setup so we can run a few farm goodies like pumps and such.
  • Like
Reactions: Bmerf and Alc
And it will even run a sleeve hitch too , I took the old lower hitch linkage from my factory tiller, ( I converted it to 3 point hitch) and turned it into a sleeve hitch. Works great .
  • Like
Reactions: MH81 and KennyP
I would really like to see how to make a 540 setup. I want to be able to run a 42" brush-hog that I found but I don't have anything that makes 540.
I want to do the same make a 540 pto I think it could be possible with different pulleys sense his uses 2 you would need to create a gear reduction with them to lower the rpm speed. Which would need larger pulleys to be used. I've done it on my compressor that the motor spins 3000+ rpm but just use the right pulleys and I got it down to 945 rpms
That's fine if you can make the right angle gear box work . you will need to drop multiple times to get to 540. Then you need to get the splined shaft. Then it must be mounted some rugged!!
Here are a few shots of my 3 point hitch today. And some shot of the front pto installation.
