1 - 4 of 4 Posts
A Little Off Plumb
Created a list of Delco Remy numbers that appear to have been desiginated as motor-generators by Delco Remy when they were made and loaded it in the manuals section. Here is a link to it
https://gardentractortalk.com/forums/files/file/5310-delco-remy-motor-generator-numbers-list/
It contains information such as voltage, rated output, rotation and other notes. The information is compiled from various sources including the Delco Remy web site. In conversation with Delco Remy it appears that there is very little information on the motor-generators left since these units are considered obsolete and I thought it might be a good idea to document what information I could find before it disappears off of the Delco Remy site forever. If you find something shown that is not correct or have more information you feel would benefit others by being added please PM me and I will try and correct or add the information.
A Little Off Plumb
Discussion Starter · #4 ·
Found that I had missed several motor-generator part numbers so I have added them to the list and replaced the pdf on the site with the updated version. I was also able to find an auto parts book from the 70's that listed a lot of the motor generator numbers by make (Bolens, Simplicity, Cushman, etc.) so I have added that information as well. It appears that some of these units were manufactured with a 6" or 7" main housing length which would probably change the overall length of the unit where it mounts as well as a clockwise and counter-clockwise rotation direction - fyi. If you wish to download the updated list here is the link.
1 - 4 of 4 Posts
