1 - 4 of 4 Posts
I was wondering if anyone has replaced the detent balls in a mf 12g garden tractor transaxle .In third gear it will pop out of gear under load. Is it a big job , and also is there a how to video out there that I can download ? Thanks a lot in advance , this is a real good forumn with a lot of good ideas. bye for now I will try to get on more often.
I have replaced several in JD 110's and 200 series
after you got a transaxle out, I leave the wheel on one side.
the side that you do not remove the transaxle bolts from the case.
I flip it up on the wheel, so that the axle are vertical - easier to work on
after you got the case apart then you can remove the shifter folks.
then you can remove the folk from the shaft - be careful if you want to reuse the ball
I replace both the spring and ball when I do it
to replace the folk back on the shaft you should remove the c-clip on the shaft because of the bevel on the end of the shaft
that makes it easier to put the shaft back on - because of the spring and ball
you need to push down on the ball to go back on the shaft and replace the c-clip
for me that is the easy part
I have a hard time getting the shafts alined with the case when puttng back together
hope this helps a little
you should get the manual - it will help a lot
it should be in the manual section - transmission manuals for you to download
One of our members did do a write-up on their transmission build from a Massey tractor, but I don't think it got pinned the way it should have been. I'll look and see if I can find it.
  • Like
Reactions: gismo
1 - 4 of 4 Posts
