1 - 15 of 15 Posts
did bolens make a 2cyl diesel in 1975? if so was it any good? how do they start in cold winter? glow plugs or no? how long of a life do the diesels have compared to the gas ht20's? found one for sale just trying to get some opinions on them
Bob's Lawn and Garden LLC
Quick answer is no they did not. What are you looking at and we could narrow it down as a few different engines came in them.
Deceased
The earliest diesel marketed by Bolens was the Iseki built ones in 1978: G152, G154, G172, G174.
The first Bolens built diesel was the HT20D/HT22 in 1980.
What model are you looking at?
That is a HT20d and has a Wisconsin 2 cylinder diesel year is a 1980 or 81 only years made and the lever is for the hi/low trans in it.
I found that on craigslist awhile back.... I posted it under one of the posts Sam made about being unable to find a HDT1000. I'm not a huge fan of non original tractors - but that would look cool as a pulling tractor
Discussion Starter · #11 ·
when you say the lever is for high/low trans....(and please bare with me im learning as I go) is that like the two speed on an ht23? I have a ht20 and it does not have that lever?
Deceased
The HT20D is basically an HT23 with the diesel engine instead of the Kohler K582,
Deceased
They do not have glow plugs.
They can be hard to start, but there are 'cures' for that.
Bolens did have a 'Cold Start Kit" for them.
With mine, a PO used two glow plugs and installed them in the air intake chamber. That lets me pre-heat the air going into the cylinders, and it helps a lot with starting in cold weather.
I've started mine in the 20* F range with no problem.
I also use Opti-Lube XPD in my fuel for the lubrication, but it also raises the Cetane rating as well, which also helps in starting.
1 - 15 of 15 Posts
