1 - 7 of 7 Posts
Is there anyway to disengage the transmission on a Massey 12h so it can be moved easily?
It has a "free wheeling" valve that you turn, I think its on top of unit (been a while), looks like a nut with bar thru it
From the rear of the tractor, face forward and move to the left side footplate. Look under the tunnel at the front of the wheel, you should see a "T" handle up at the top of the hydro unit, it faces towards the engine. One end of the "T" is longer than the other. Turn the handle 180 degrees or a half circle. That should disengage the hydro.
  • Like
Reactions: chiefgoodman
Discussion Starter · #7 ·
Thanks a lot guys. I found it. Should make it easy to move tomorrow :thumbs:
1 - 7 of 7 Posts
