1 - 1 of 1 Posts
DIY electric garden tractor, and it could be charged by solar, zero pollution
2hrs cutting approx 2 acres or 8-10 hrs pulling trailer on a charge
Converting to battery power is a great idea for a garden tractor I converted one 15yrs ago, I used the 3 separate motor design and it is still cutting grass on a daily basis, it is amazing how it never breaks down and needs almost no maintenance, I renew the batteries every 7 yrs I am just on my 3rd set now, my design will cut up to 2 acres on a 50cent charge there are no belts or pulleys and no oil on the entire tractor, it can pull a trailer for about 8hrs on a charge, because battery run time is the most important aspect of most conversions I paid particular attention to the most efficient design, I used 3 separate small motors one for the drive with electronic speed control and two smaller with a cutter blade mounted on the shaft of each cutter motor ,total amperage when cutting grass is approx 40amps, (2000watts) this design only uses the battery power req to do the job, very little wasted battery power, it uses magnetic breaking of both tractor and cutter blades and automatically applies parking brake when you stop or get off the seat, an amazing tractor. electrictractor.net
Video #5 Ploughing Snow
Video #4 Ploughing Veggie Garden
Video #3 The Little Electric Tractor That Can! cutting grass
Video#1 on youtube
and
1 - 1 of 1 Posts
