Well, started as just a 3pt, but got more anyway! Here's some pix. Kinda dark, was gettin' home about sundown, took quick shots. It's a 1655 with broken Onan engine laying in it. Has front pto, which also must have run the deck with shaft, instead of belts out the back. Wondering if that might go on my 1650 if I didn't use the deck? Front axle is heavier also and has bolt on wheels. Will that switch over easy? Tires are wider then, about same OD. No rear pto, it stayed with PO for his. The tin on this one is prettier, and the plastics, so maybe putting those over to mine. They are just covered with dirt, from sitting in shed. Gonna let the rain wash it off first for couple days. Might be having some Onan parts for sale. Engine is half disassembled, not sure yet it's problems. Carb is half there,one head off, tin all pulled off. 3pt was better than one I bought earlier so might be using that on mine instead. Check it out!
