1 - 8 of 8 Posts
Does anyone have a copy of the Diagram for the optional cyclops light kit for the EK10 tractors?
I want to get an OEM style kit together to mount on my tractor for snow blowing but want to wire it to factory specs.
I know I have had my hands on the diagram but now I cant find it since I "Organized" my literature into filing cabinets :wallbanging:
i think you may need an extension pole to mount it on right now with all the snow . I can't find anywhere the switch would go otherwise i would try to fit something together , but i had thought about at least putting a couple of led type lights behind the engine cover grill for the rear.
the only mention of a light kit is for the estatekeeper i can find is the one on the back of the snow removal equipment cat. form no.551821 ,with the optional equipment and no diagrams in my manuals . sorry i can't help any more .
Looking at the EK10 schematics and to make an easy job of it you will need to connect a wire to the Ignition terminal of the key switch to one terminal of the headlight and the other headlight terminal to chassis ground. That would allow the key switch to turn off the headlight when you turn off the tractor.
Just now saw this thread my estate keeper has a stock light kit on it. The previous owner's widow said they ran a dealership in Wisconsin and he liked to keep all his equipment stock or at least only with optioned equipment. She said the light on the column of my tractor was from their old dealerships parts inventory. Not sure you are still looking but I could always check it out if you want to message me.
1 - 8 of 8 Posts
