1 - 7 of 7 Posts
Been seaching all mornning for the correct fluids for my new toy... :dancingbanana: I picked up that 1556 I had talked about ( pics to come ) NOW,,, type a trans-- Is it still available ?? OR What goe's in an Eaton 10 ? What wix filter ? 51307 OR 51452
Air filter ?? 42373 is what NAPA shows..
What kinda grease will give the chain on the caster a good coat. ? It's so expossed. It will be constantly in snow..
I'm still reaserching the lower shoot handle One end has the hook and the other goes to the worm gear. It is broken just where it goes in to the shoot houseing .
It's 19 degrees out this mornning ( sat ) But a'm itching to go out and play...Going to check out the gear lube in the caster deck. AND of coarse take some pics
This is my first tube SO I have lots of ???????
Thanks sodisr
Deceased
For lubing the chain on the caster, I'd think that a good motorcycle chain lube would work.
They are always exposed to the elements, and probably work as hard if not harder than the chain on the caster.
  • Like
Reactions: sodisr
Discussion Starter · #3 ·
Thanks O B.. How about the filters ??? NOW the P O said he never changed the hydro fluid cause it never needed it or was low.. It is bright red,, but I would like to change it in spring.. If I have to top it off this winter,, what would you use ?? I've looked into the fluids that go into a Eaton 10.. TYPE A , But reading on you should not mix different types of ATF,,, They are not compatable with certain brands... Type A,,,Type F,,,dextron III ..
What air filter is used on the 1556.. tecumseh
What hydro filter ???
Bob's Lawn and Garden LLC
I have the air cleaner and the hydro filter in stock if you want to send a pm.
Discussion Starter · #5 ·
Thanks Bob... I kinda need the air filter today... But I will sure keep you in mind when the hydro gets changed
No problem the part number for the air filter is a 32008 that is the Tecumseh number. Not sure of a aftermarket number.
Discussion Starter · #7 ·
I picked up an air filter for the 1556 at Napa.. Thanks all !!!
Napa-- Wix filter # 7--02204
It's the one thats 6" round and goes on tec. engines
Also fits Gravely 1090
Kohler 235116
Case C-28883
Cub Cadet IH 385168R2
John Deere AM 31400
Tecumseh 3200
Nivel 2111
Wisconsin L0194
1 - 7 of 7 Posts
