1 - 8 of 8 Posts
I had the great fortune of being able to attend Daniel's plow day back on the 1st. I was also fortunate to have one tractor and plow combination that worked great right from the start.
This Is The Story of The Other Plow:
The other tractor/plow combination struggled. Initially, the plow didn't want to dig in properly, and because the landside didn't have a good furrow, the plow wanted to pull all the way to the left but only going down an inch or so mostly at the point. I tried some adjustments, and got a bit better bite, but it still wasn't working well at all. I asked for advice from other plowers who were most helpful. When I got back to the truck to put their ideas into practice, I found my biggest problem. I had a "D" ring clevis hooked to the Massey's rear hitch, and it was interfering intermittently with the sleeve hitch.
"Aha!" I thought, fix that and all my trouble will disappear. So I pulled off the "D" ring Clevis and sure enough I began to get more consistent results, though still not the depth I wanted - 2-3 inches instead of 4-5. Though the rest of the day I adjusted here, and adjusted there, moving the sleeve hitch down and back up again, adjusting the depth control. Nothing had much effect on the depth the plow was running.
It wasn't until I got home and unloaded the two plow and looked at them side by side that I began to realize some of the problems I was facing. This plow was the one that worked well:
Automotive tire Wood Automotive lighting Bumper Motor vehicle
This one was the one that just wouldn't go deeper:
Helmet Motor vehicle Wood Grass Fender
Notice the difference in the shape of the points? Also, I had never realized how much the "heel" ? was hanging out away from the moldboard. Not having grown up with moldboards, I simply hadn't looked closely and compared these two, even though they are stored side by side.
So I ordered a new plow share from Brinley. Not cheap, but the best way I knew to salvage the plow. The new share was a better match for the moldboard length, as well as having a much better defined "point".
Tire Wheel Plant Automotive tire Tread
Grass Wood Garden tool Gas Lawn
Wheel Art Creative arts Grass Wood
I originally intended to simply paint the moldboard to prevent rust, but one thing led to another, suddenly the wire brush was running amok on the plow beam as well, and - well - Pictures speak a thousand words:
Plant Monoplane Automotive exterior Propeller Art
I think that may help with the depth issue!
I plowed with my ferguson tractor and plow in a plow match once, and finished last. The next year I put new points on the plow, and came in second. Points make a big difference.
Noel.
Discussion Starter · #7 ·
Good Stuff on figuring out why the plow not working to good, now you have to goto another plowday and really test it. :thumbs:
Absolutely! Just need to find one in North Carolina or nearby and fix some issues that cropped up on both tractors.
Discussion Starter · #8 ·
I had a very late notice opportunity to attend a Tractor Show and Plow Day in Salemburg NC which was being held to raise funds to support the local food bank. I took the 12 Gear Massey and the plow with the new plow point. We had substantial amounts of rain overnight and I doubted we would plow, so when I arrived my daughter and I toured the displays first to see what was there.
Wheel Tire Sky Cloud Vehicle
Wheel Tractor Tire Vehicle Automotive tire Wheel Tire Vehicle Automotive tire Building
Wheel Tire Vehicle Motor vehicle Automotive tire Wheel Tire Vehicle Motor vehicle Tractor
Tire Wheel Shorts Automotive tire Vehicle Tire Wheel Vehicle Automotive tire Tread
I truly enjoyed seeing this line-up of Masseys, and would have loved to put one of my better looking GTs in the line-up, but the 12 G is more of a survivor in work cloths at the end of a long day, not a beauty queen. There were a number of John Deere tractors, several IH and a few others which escape me. Not one single Ford that I recall, and not one true GT, though there was a Cub Lawnboy.
Shortly after we saw the Big Articulated IH - with home built 8-10 share moldboard with depth regulated by depth wheels, he cranked up and headed to the field to see if he could begin plowing. Another more traditional IH joined him, and after I watched a few passes I decided to join in myself.
Tire Wheel Vehicle Sky Plant Tire Wheel Vehicle Sky Tractor
Wheel Tire Vehicle Tractor Automotive tire
It was great! I had already flattened the plow quite a bit in anticipation and still had to continue to flatten the plow. I settled on a depth of around 3-4 inches as the soil was sandy but very wet. The plow was digging so well, the heel was actually all the way down at the bottom of the furrow and would leave a little track from time to time.
My daughter had gone with me and plowed sitting in my lap for the first 45 minutes. It was rather rough going for a GT as in addition to being sandy AND wet, the field had also been worked over by a disk or something similar. I stayed away from the big boys, grabbed a small corner of the field for myself. After we had lunch, I left my daughter resting in the truck while I went back and plowed some more. I didn't take any pictures, and the two short videos I took seem to have been damaged when they were downloaded to Windows.
1 - 8 of 8 Posts
