So I started to build a 3 point hitch for my ford 165 diesel. I found I lot of the information on this site. I thought I would share were I'm at with it. I have a the rocker shaft made. My lgt 145 has this rocker shaft from the factory so I was able to measure and copy it. I'm going to make it as close as possible to factory so it the parts are inter-changeable between tractors.
Also started on the the lift links. They are made using 1/2" pipe and 3//4" bolts. One end just swivels thru a 7/8" nut, I ground the head of the 3/4" bolt to fits freely inside the pipe. Also drilled a hole in the pipe so a pin or spud wrench can be inserted to make adjustments.
I like the brake attachment on the press! I have something similar. Here a page from the parts list. Looks like the rear bolt attaches at the far side of the trailer hitch.
The trick to making it is sandwiching all the plates together tack welding it than drilling all the holes at once. That way they are all lined up. And lots of measuring. It helped that my 145 had the factory rocker shaft on it.
Looks good Ryan. The factory set up sucks hard core, but looks good doing so.... I put countless hours into mine getting it refined to what I think works the best and is the easiest to use.
Also 3/8"x2" is not tough enough and you will bend them with a tiller on the rear.Been there ...
1/2"x2" 1045 or 1050 works perfectly and make them straight with out any bends. Rocker shaft arms on the outside of side plates instead of the inside so the lift links are straighter. It aint easy but when done it works AWSOME!!.
Yes... I got the inspiration to build this from your thread on your hitch. The reason I went to the factory setup is so that it is interchangeable between tractors.
I used turn buckles on both rhe old designed arms and the new ones. Old arm design used them on the outside of the arms(more difficult to ajust) new ones were on the inside and easier to ajust. Also they pulled the arms into the attachment not against the pin.
I started building thicker lift arm for this three point, as recommended by Keith. I used 1/2"x 2" mild steel flat stock and bent it used my 20 ton shop press. The press was pretty much at its limit. A couple of holes to drill and some paint left to do.
