Ford model-T streetrod
5436 Views 111 Replies 11 Participants Last post by  jhn9840
..... This will be a long term post thru the winter and on into the summer as weather permits. .....
This is going to be my next project.
It is a Ford model-T that I had started building into a streetrod and it ended up being put into storage back in the early 1990's.
I pulled it out of storage in the summer of 2021 with the intention of getting it running and selling it to raise money for working on other projects.
Tire Wheel Automotive tire Vehicle Car
I have since changed my mind about selling it.
However, I no longer want to use the Hemi engine that is in it so I have pulled that out and I have that for sale.
So this is what I'm starting with now.
Tire Wheel Vehicle Car Motor vehicle
And this flathead V-8 is the engine that I'm going to put in it. It is a 1949 to 1953 engine with 1948 or earlier finned aluminum heads on it.
I got this engine from Fred Sibley in Elkhart, Indiana in the late 1970's.
Fred Sibley is well known for building jet powered dragsters and he is in the Drag Racing Hall of Fame.
I haven't checked the identification numbers on this engine yet so I don't know if this is a Ford or a Mercury engine.
If it is a Ford, then it is 239 CID with 110 HP. If it is a Mercury, then it is a 255 CID with 125 HP.
This engine was used in a dragster back in the late 1950's and early 60's. It has a Pro Racing Model intake manifold on it that does not have the boss on the front for mounting the generator onto.
Gas Auto part Machine Metal Engineering
Ordinarily, I would sell this intake and get one that has a generator mount on it but this has been welded on the side of the fuel pump mount so I wouldn't be able to get much for it.
I could smooth the weld down so it wouldn't be noticeable but I still wouldn't want to sell it because I'm not the one who did the welding and I don't know if it can be trusted to not brake back out later.
Artifact Composite material Gas Concrete Art
I also have a stock single carb intake manifold off a 60 HP engine that were made from 1937 thru 1940. This is a shorter manifold then on my engine and they really aren't worth very much.
However, the generator mount on the front is the same as the ones used on my engine so I have cut the front off this manifold.
Wood Gas Auto part Nut Concrete
If you look at the side of the carb mount, you can see a long crack in it so this manifold is scrap anyway.
Gas Musical instrument Font Metal Fashion accessory
The mounting holes on the front of both manifolds are the same so I milled the mounting bosses down on both sides of the front of my manifold.
Bicycle part Rim Nickel Nut Auto part
This way, I can set the front part of the other manifold on top of the front of my manifold.
I will weld these two parts together but I don't want to do that until I have the engine here so I can bolt both of these pieces together on the engine to help keep it from warping when I do the welding.
Gas Electric blue Wood Metal Auto part
Auto part Gas Metal Circle Wood
I know ... this seems like a lot of work but these two manifolds aren't worth anything as is and a new one can cost anywhere from $300 to over $1,000 depending on who manufactured it, what style it is and how rare it is.
Besides, this gives me something interesting to play with and when I'm finished, it will look like it came from the factory this way.
See less See more
9
  • Like
Reactions: 5
1 - 20 of 112 Posts
Ray, right above the blue tape in the carb mounting looks like a crack. May not be, but looks that way.
  • Like
Reactions: 4
That's a pencil mark from making measurements.
  • Like
Reactions: 5
Good! Sure looked like a crack though!
  • Like
Reactions: 4
Looks like a fun project. Looking forward to following along.
I worked on a model T build for a customer a quite a few years ago. No gen mounts on the engine so we added a pully to the drive shaft and ran a single wire alternator off from that. Alternator was completely hidden under the car. Worked great for his needs.
  • Like
Reactions: 5
Another great project thanks for sharing
  • Like
Reactions: 5
Part of the edges on the generator mount are broken off.
Gas Auto part Fashion accessory Metal Automotive wheel system
So I cut that area off of the manifold.
Gas Wood Toy Motor vehicle Auto part
Then I machined out a block of aluminum.
Rectangle Gas Composite material Aluminium Automotive exterior
This fits snugly onto the back of generator mount.
Wood Office ruler Household hardware Tool Metal
The block of aluminum will be welded onto the front of the manifold.
Wood Gas Electric blue Metal Plastic
And the generator mount will fasten onto it.
I still have to drill and tap the hole in the center for the mounting bolt.
Tool Auto part Machine Bicycle part Wood
See less See more
6
  • Like
Reactions: 5
I had made brass air cleaners for the four carburetors that are on the Hemi engine. When I put the Hemi up for sale, I bought four chrome air cleaners to put on the carbs and kept my custom made brass ones.
This is what one of the brass air cleaners looked like on a carb.
Automotive tire Wood Floor Tread Gas
I have 4 brass air cleaners and only 2 carbs so I'm going to make a pair of custom " T " shape air cleaners.
These are the parts that I'm going to use to make the air cleaners for the flathead.
The aluminum tube will be cut in half to form the top cross tube of the " T " for each air cleaner.
The two aluminum tubes will then be machined out so that a brass air cleaner will fit on each end of the tube.
The two round chunks of aluminum are the centers that I cut out of the blocks of aluminum that were used to make the rear wheel adapters for the tractor that I just finished.
These will be the center down tube for each air cleaner.
Wood Gas Masking tape Nut Household hardware
First the center has to be cut out of each of the round blocks.
Water Gas Machine Art Metal
Here is one with the center cut out of it to form a thick aluminum ring.
Automotive tire Wood Rim Household hardware Gas
The ring is chucked up in the lathe and the center is machined out to the inside diameter of the top opening of the carb.
Wood Gas Machine tool Machine Engineering
Then a counter bore is machined out to the outside diameter of the carb.
Automotive tire Rim Wood Gas Cylinder
Checking to make sure that the Stromburg 97 carb fits nicely.
Gas Machine Engineering Nut Auto part
The ring is then gripped on the inside diameter and the outside is turned down.
Cylinder Rim Gas Auto part Machine
See less See more
8
  • Like
Reactions: 5
The rear axle is a 9 inch Ford with positraction.
I wanted the looks of the old style quick change rear axle but I didn't want the gear noise or the problem of expensive and hard to find parts.
So I made a oval ring out of sheet metal that is welded it to the back of the axle housing and bolted a Frankland quick change rear cover to it.
This way I have the dependability of the Ford axle with the looks of the old style quick change rear end.
Wheel Tire Vehicle Automotive tire Tread
The fenders are for a 1915 Ford. They were special order from Rootlieb and they are 3 inch wider than stock so they cover the wider tires.
This is what they looked like when I bought them in the early 90's but they have over 30 years of sitting in storage on them now.
Automotive exterior Bumper Automotive design Triangle Vehicle door
Automotive tire Automotive lighting Automotive exterior Rim Automotive design
I built the chassis frame out of 2x3 inch box steel. The lower control arms for the rear axle are 2x2 steel and they have a sway bar mounted on them.
Bumper Wood Automotive exterior Gas Machine
The two gas tanks are made out of aluminum with baffles inside to keep the fuel from sloshing around a lot.
Bumper Trunk Gas Automotive exterior Tints and shades
They both have an aluminum heat shield with about 1/2 to 3/4 inch air space between the shield and the tanks.
Wood Tints and shades Linens Analog television Rectangle
Here are the two tanks. I took advantage of any extra space under the frame rails so I could get as much capacity as possible. The larger tubes at the bottom are the fill tubes and the smaller tubes at the top are the air vent tubes.
Automotive exterior Gas Composite material Auto part Nickel
Here you can see how the tanks fit on the sides of the frame.
You can also see the two upper control arms for the rear axle. They are mounted at an angle to keep the axle from moving sideways.
The finned round canister on the right side in front of the axle is where the fuel goes in. Both tanks are connected to this round canister by 1-1/2 inch diameter tubes so the fuel level stays the same in both tanks.
This is also the lowest point in the fuel tanks and the hose for the electric fuel pump comes off the bottom of this canister.
The fuel filter is mounted on the left side under the upper cross frame ( chrome can with red top ).
Tire Automotive tire Vehicle Tread Wheel
The tube coming out of the top of the round canister is connected to the fill tube that is behind this door in the left side of the turtle deck. The air vent tubes are also connected to the fill neck tube and vented thru the gas cap.
Motor vehicle Bumper Fender Gas Vehicle door
See less See more
9
  • Like
Reactions: 5
Last summer I built the dash for the model-T.
Starting with forming a piece of sheet metal to form the dash.
Automotive tire Wood Automotive exterior Bumper Gas
Then the holes are cut into it for the gauges, switches and heater controls.
Light Gas Automotive exterior Wood Automotive tire
The switches and heater controls are out of a 1953 Ford.
There are two stamped backing plates that go behind the dash with particular size and shaped holes for locating the individual control switches and cables.
Seen from the back side, there is a hole in the center of each one for a dash light socket and bulb.
Gas Audio equipment Wood Machine Kitchen appliance
I've cut a hole for a glove box and made a door for it.
Bumper Gas Machine tool Wood Machine
1/4 inch square steel rods are formed to fit the contour and welded to the inside of the door. Then a piece of sheet metal is welded on top of them. This makes the door thicker and gives it strength. Door stop brackets from another car are mounted in place on this door.
Motor vehicle Bumper Automotive exterior Wood Gas
Then a glove box latch is added.
Brown Rectangle Wood Material property Gas
Here is the finished dash getting the wiring installed.
Motor vehicle Gauge Gas Audio equipment Measuring instrument
This is how the gauges look with the dash lights on.
Plant Speedometer Tachometer Gauge Vehicle
And the dash installed in the car.
When I first started building the car over 30 years ago, I made the steering column so it would swing over toward the center to make it easier to get in and out of it.
This is with the column locked in the driving position.
Vehicle Motor vehicle Plant Fixture Steering part
Pushing up on a brass button under the left side of the dash releases the lock and the column can be pushed over to the right.
Vehicle Car Plant Motor vehicle Automotive exterior
See less See more
10
  • Like
Reactions: 5
I had left off with finishing machining the two bottom tubes of the air cleaners that will fit onto the top of the carburetors.
Next, I chucked the top tubes up in the lathe and started turning down the outside.
Cylinder Gas Nickel Automotive exhaust Auto part
This is cut down until the base of the brass air cleaner fits onto it.
Cylinder Gas Engineering Machine Pipe
Both ends are turned down and the steel brackets are fastened onto each end. These have a threaded hole in the center for the top of the brass air cleaners to screw into.
Automotive lighting Gas Nickel Cylinder Tin
The bottom of the steel brackets are fastened on with counter sunk screws. The screws holding the other end stick up above the machined surface. They fit into the milled notch on the inside of the brass air cleaner so the it can't rotate.
Adhesive Wood Household hardware Circle Rim
A hole saw is used in the drill press to rough out the hole in the top tube.
Gas Machine tool Milling Engineering Machine
Then the hole is finished machined on the mill.
Gas Machine tool Engineering Auto part Glass
The two bottom tubes are clamped together and a hole is cut into the center between them.
This forms a " U " shaped cut on the ends of both of the tubes that matches the inside diameter of the top tube.
The bottom tubes are fit into the center hole in the top tubes and welded on the inside.
Fluid Liquid Gas Machine Auto part
Here are the finished air cleaners for the two carbs on the flathead engine.
Bicycle part Household hardware Auto part Rim Metal
Wood Auto part Gas Metal Fashion accessory
See less See more
10
  • Like
  • Love
Reactions: 5
Those turned out really nice! I like the contrast between the two metals.
  • Like
Reactions: 3
My intake manifold has the carburetors spread wide apart so both carbs are sitting over the intake ports on the engine.
This is a good design for a high performance engine but it isn't so good for a street driven car.
With this carb placement, both carbs have to be run together at all times and they both need to be synchronized with each other so one isn't running richer then the other one.
I want to be able to run mostly on just one primary carb with the other one kicking in when the engine is running at higher RPMs, like a 4-barral carb operates.
In order to do that, I need to make a plenum chamber that both carbs would dump into so the gas and air are mixed evenly before it goes on into the main intake manifold.
There are several intake manifolds on the market that are designed this way but because I'm working with what I have, I have to build my own.
I have a piece of 1x4 rectangle aluminum tube that I'm going to use for the plenum chamber.
I've machined down a block of aluminum so it will fit snugly inside the rectangle for the end cap.
Wood Flooring Floor Wood stain Hardwood
Wood Floor Flooring Rectangle Road surface
Both end caps are fit in place and the holes are drilled for bolting this onto the top of the intake manifold.
Wood Gas Engineering Machine tool Machine
Table Wood Gas Hardwood Machine tool
The plenum chamber is turned over and an old carburetor base is bolted onto one end. This is used as a jig for drilling out the two port holes in each end.
Wood Gas Machine Bumper Automotive tire
Here's what it looks like with the port holes drilled and the end caps removed.
Rectangle Composite material Wood Gas Metal
Using a ball nose end mill, I'm roughing out the port hole area in one of the end caps.
Wood Gas Plastic Transparency Hardwood
This is smoothed down more with a Dremel tool to form a radiused surface at the end of the plenum chamber.
Wood Gas Auto part Font Metal
Here's how it looks inside with the end cap fit back in place.
This gives a rounded surface that helps to direct the air - fuel mixture down into the port holes rather than just have a flat squared off surface at the ends.
This plenum chamber will be bolted back onto the manifold later and the end caps will be welded on.
Now I can place the two carburetors closer together when I mount them on top of the plenum chamber and hook them up with progressive linkage.
Composite material Gas Circle Auto part Metal
See less See more
10
  • Like
Reactions: 5
This is the end cap for the other end.
Grey Wood Font House numbering Metal
The plenum chamber with both end caps on.
Composite material Rectangle Automotive exterior Auto part Aluminium
See less See more
2
  • Like
Reactions: 5
I have an old Almquist intake manifold like this for mounting two carbs on a single carb intake.
White Automotive exhaust Motor vehicle Gas Exhaust system
It's small enough that I was able to put it up on my small mill in my train room to mill the bottom off.
Wood Gas Tool Office equipment Metal
The plenum chamber is to wide to fit on my small mill so it had to be set up on the big mill out in the un-heated garage to cut a hole in the center of it.
Wood Bumper Gas Automotive exterior Machine
The Almquist manifold fits snugly into the hole.
It's going to be to cold to work out in the garage for awhile but at least I was able to get this much done so far.
Gas Clock Plastic Machine Metal
See less See more
4
  • Like
  • Wow
Reactions: 5
Look at what I got today. ....
Rebuilt original Ford Holley 94 carbs set up for dual carb intake.
These are from Wolf Enterprises in San Antonio, Florida.
Drum Membranophone Gas Musical instrument Font
Gas Camera accessory Machine Cylinder Metal
Motor vehicle Gas Rolling Machine Auto part
Automotive lighting Gas Auto part Automotive exhaust Motor vehicle
See less See more
4
  • Like
  • Love
Reactions: 5
The collection of parts for this project is getting bigger.
This is the progressive linkage for my two carbs.
This linkage will allow the engine to run of one carb most of the of the time.
The other carb will start to open up at 65 percent throttle and both carbs will be open 100 percent at full throttle.
Font Wood Fashion accessory Rectangle Tool
See less See more
  • Like
Reactions: 5
Had some warm weather so I was able to get a little more done on the intake manifold.
This is actually my second try.
On the first plenum box, I had drilled the two 1-13/64 dia. fuel port holes in each end.
When I went to weld the end caps on, there wasn't enough material between the fuel port holes and the end caps to maintain a good weld.
So I got another piece of 1x4 inch aluminum tube to make a new plenum chamber.
Again, a hole is milled into the top of the plenum so the duel carb manifold fits into it.
The open ends of the bottom of the duel carb manifold are filled in with pieces of aluminum.
This re-forms a center outlet on the manifold.
Automotive lighting Tin Bumper Rectangle Automotive exterior
I used pieces of the aluminum running board to do this so the inside has the ribs in it to help direct the air flow.
Automotive exterior Wood Bumper Gas Rim
This manifold is then welded in place on the inside of the plenum.
Gas Rectangle Automotive exterior Composite material Automotive wheel system
The plenum is then bolted onto the flathead intake and I've started welding the two end caps on, up to where the bolts are.
Gas Machine Nut Automotive wheel system Engineering
The bolts are removed one at a time and that area is finish welded.
Bumper Gas Automotive exterior Auto part Automotive wheel system
The plenum is removed and turned over to finish welding along the underside of it.
The welding on the left end cap is completed and I'm getting ready to do the last weld on the right end cap.
I use the torch to heat up the end cap each time to make it easier to weld the 1 inch thick cap to the 1/8 thickness of the plenum tube.
These welds will be smoothed down flat and once that is done, then I can re-drill the two large fuel port holes on each end.
Gadget Gas Technology Cassette deck Bumper
See less See more
9
  • Like
Reactions: 5
I machined out a plate to fill the hole in the bottom and it has the ribs on it to help with air flow.
Gas Composite material Rectangle Auto part Metal
The welds are smoothed down and the two fuel port holes are drilled into each end.
Automotive exterior Bumper Rectangle Gas Auto part
Then I polished the plenum chamber and duel carb manifold.
Rectangle Wood Flooring Gas Hardwood
The filler plate for the bottom is fastened to another aluminum plate that is 3/8 inch wider all the way around.
Grey Road surface Floor Font Flooring
This is then fit onto the bottom and fastened down with #2-56 stainless screws.
RTV sealant is used for the gasket and the screws are coated with Lock tight.
Once the RTV has dried, I'll trim off the excess.
Rectangle Gas Auto part Metal Aluminium
See less See more
5
  • Like
  • Love
Reactions: 5
How it will look with the carbs and air cleaners on.
Wood Machine tool Gas Machine Cylinder
Wood Gas Machine tool Machine Lathe
Wood Gas Machine Machine tool Hardwood
See less See more
3
  • Like
  • Love
Reactions: 5
1 - 20 of 112 Posts
