I'm sure all of you have seen pistons installed in and engine at one time or another so I'm not going to bother with taking photos of that.
So, with the pistons all in and everything tightened down, it's time to start putting the engine back together starting with the timing gear cover.
I haven't paid much attention to that part and as soon as I picked it up, I knew that I had another problem. That boss on the inside with the hole in it is suppose to hold the spring loaded plunger that rides against the end of the camshaft to keep it from sliding forward.
This is what that plunger looks like and I realize now that there wasn't one in there when I pulled the cover off.
A new timing gear has been put on this engine at one time and they forgot to put the plunger back in when they put the cover back on.
I can order one at $3.99 for the plunger and $12.76 for shipping and I wouldn't get it until Tuesday - at the earliest.
Naturally, this style of plunger is very old technology and the instructions for it says to be sure to grease it really good or it will make a nasty noise when you first start the engine.
Now days, there would be a hardened ball that would ride against the end of the cam with the spring putting pressure on it.
So I decided to up-date this old engine and I came up with a 5/8 diameter ball bearing and a spring just the right size.
There is already a chamfered hole in the center of the camshaft for the ball to ride on.
You can see here how good a condition the fiber cam gear is and you can tell that it has been changed because there are marks on the left side of the nut where they used a hammer and chisel to tighten the nut.
With the spring and ball set into the cover, I held it up to the engine and you can see that there is about a 3/16 wide gap for compressing the spring.
That should be just the right amount of pressure on the camshaft.
The rope seal is fit into the cover and it is bolted on.
This leaves quite a bit of the rope seal sticking up that needs to be trimmed off.
The ends of the rope seal need to be trimmed off so you leave a little of it sticking out, both on this cover and on the oil pan, so the ends will be compressed together when the pan is bolted on.
I use a washer that is about .100 thick and I've trimmed it to form a U-shape.
This is placed around the rope seal and then the ends can be trimmed off evenly with a razor blade.
This leaves a nice even amount of the rope seal sticking out.
A light coating of grease is spread on the pulley shaft so there isn't a dry surface rubbing against the rope seal.
The rope seal on the oil pan is trimmed the same way and the pan is bolted onto the block.
