1 - 8 of 8 Posts
I noticed the front wheels had quite abit of play in them.. took off the dust cap to tighten the nut.. NO nut !!
There is a coller with an allen going thru it.. nothing like my LG frame.. Now if that is correct,, are shims the only way to take up some of the play ???
Are there bearings in it at all or just bushings... I want to take it appart but thought I would ask first..
I could not find a manual for the 1556 to show the exploded view of the front wheels...
I'm also trying to find the Model and serial #s on the body of my TF 1556.. I have them from the engine but not the frame
Any help on either topic would be APP. Thanks sodi..
There should be two ball bearings(inner and outer), a washer, set collar and a #1187 857 Cap Screw 1/4-20 x 1.
  • Like
Reactions: JRJ, sodisr and Alc
Watch which manuals you are looking at as not all tube frames had the same bearings in their wheels.
My 1556 Parts list has the Ball bearing as a 1185616
Having a little play is normal and can be expected after 40+ years , you can add more shim washers if necessary.
They are a Roller bearing not a tapper bearing like the Lg Frames So adding shim's are going to do nothing besides endplay I do believe you could find a Crossreference for the bearings
  • Like
Reactions: MyBolens1053
Your local bearing supply house can likely cross-reference those bearings if you take them in. It does sound like you have a roller bearing or bushing, and either will be worn after so many years. A bit of warning, I replaced the front bearings on my Massey, and while it did help, there is still some movement, probably where the old bearings wore a bit on the axle.
Discussion Starter · #7 ·
By looking at it ,, It seems like the play is in-and out. I think shims would work. 1 on inside 1 on outside . That's what I thought I was going to do by turning in the nut a little and take out some of the end-play......Now to find washers with that dia. inside..
Thanks sodi
Discussion Starter · #8 ·
Got the washers and put them on... AFTER I repainted the rims in and out :mad2: It burns my a$$ when someone paints a tractor and leaves overspray on the wheels and tires... Anyway got the washers on ,,bearings seem OK.. But the control-arm-bushings seem to be the worse,where most of the play is coming from.. I read you can still get the bushings,, Have to call BOB , or call MCMaster for some bushings.. Do those bushings just press out or tap out ??? I couldn't make out what pt.# those where,, or the dimentions I need. Time for the calipers !!
1 - 8 of 8 Posts
