1 - 7 of 7 Posts
Im a proud new owner of a Bolens FS-942 mower it needs some tlc but i got her running an cut a lil bit yesterday but i need a wiring diagram for the key ignition and for the 11hp Briggs motor as i found 2 wires melted pretty badly today while inspecting it. The one pic shows my new machine the other the badly worn out key ignition i replaced but cant figure out which wire goes where on the new switch :/
Is there just two terminal to the switch or are a couple rusted off.
Welcome aboard I'm sure someone will chime in with some info for you. The tractor appears to be in nice condition.
  • Like
Reactions: papabear73
A Little Off Plumb
Looks like the part number for the original ignition switch may be 1813185 if it is the same as this parts break down - http://members.tripod.com/jacques_lacasse/Bolens_site/FS11_parts/index.htm
There is a parts break down in the manuals section for a 940 that shows the same switch number 1813185
Found on the MTD site that 1813185 is replaced by this switch and shows some other Bolens part numbers it replaces
http://www.mtdparts.com/equipment/mtdparts/925-0267b
One of the other numbers it shows as replacing is 1734196 which according to the excel sheet that LPBolens put together fits a G11 1155-01
Attached is a picture of the wiring diagram of the G11 1155 Bolens tractor
There are definitely some variables as to whether this is the same wiring as what your 942 uses and whether the switches are indeed the same but given the information I have posted it may be worth checking out - use at your own risk as the switches may be different and I would hate to lead you astray and see you have more melted wires. This may help you if you cannot find any better information on the switch as it shows what terminals connect in the various positions.
Discussion Starter · #6 ·
thanks for the replies everyone. I do already have some melted wires but not sure if i melted them or if they were not melted when i got her. im gonna try to use the wiring diagram to match up colors to letters on the ignition switch see if it works. will post back my results :D
Discussion Starter · #7 ·
there are 5 terminals on the back of the switch one broke off one rusted out on mine guy said it still worked when he delivered it to me not sure how it did but thats what he said
1 - 7 of 7 Posts
