1 - 12 of 12 Posts
Deceased
Running into a problem installing the hydro lift on the G10.
The throttle and choke cables are in JUST the wrong place.
I looks like my only option is to run those cables THRU the belt after it's installed.
Has anyone else mounted a hydro lift on a G10? If so, how did you deal with this?
Here's a couple of pics to show you what I'm looking at.
This might not be the correct way but on my Economy Jim Dandy uses a link belt and that would make it easy for you ,to install and remove DSC07672.jpg
  • Like
Reactions: OldBuzzard
Deceased
Discussion Starter · #3 ·
Ya know, that's not a bad idea.
I'll have to see if I can find one narrow enough to work on the pullys.
Deceased
Discussion Starter · #5 ·
Yeah, the G10 seems to be the "Red headed step child" of the Bolens line.
That B&S engine has made installing this hydro lift a real pain in the patootie.
I did find this online:
Saw Accessories - 4 FT. POWERTWIST LINK BELT
Turns out that Hartville Tool isn't all that far from me so I'm gonna run down there today and try one of these. Sure will make things a lot easier IF there is one the right size.
Deceased
Discussion Starter · #6 ·
FINALLY got a roundtuit, and got the belt from the above post installed.
Worked slicker than a smelt, and the hydro unit is functional. :dancingbanana:
Only thing missing now is the little piece to support the snowcaster crank. I'm guessing that a piece of 1/4" flat stock with the appropriate sized holes drilled in it would suffice.
Now I gotta put new drive belts on the 800. Looking at the directions in the "sticky post", I think I'm going to need to "fortify' my self...it looks like it may be a 2 six-pack job
In case you need one, here's a spare.
Good to hear the hydraulics are working :bounce:
Nice find on the service bulletin Brian. I must say that you never give up. Keep up the great work.
Deceased
Discussion Starter · #11 ·
When that bulletin was issued the G10 had the TEC HH100 (73-75).
Mine is a '77 with the B&S.
Good find though.
1 - 12 of 12 Posts
