1 - 13 of 13 Posts
Deceased
I got it off the trailer. Since I couldn't get to the freewheeling pin, I just used the 1256 with the Ag tires and a tow rope, and drug it off until the rear wheels were on the ground, and then just drove out from underneath it
It need a a battery, but I think maybe I'll borrow one from one of the 1256's for now.
GOOD NEWS is that if it's not running it WILL go into reverse. I have a sneaking suspicion that the brake isn't working good enough to stop the drive shaft, and that it's still spinning enough that it won't allow you to get into reverse when the engine is running. If that's the case it should be an easy fix.
It's going to need tires. Both right side tires are flat, and the left sides are pretty weather checked.
I'm kicking around the though of putting Ags or possibly ATV tires on the rear and V61's on the front. At least if I can get them in the proper size.
  • Like
Reactions: KennyP
if it were mine i would try to keep it original so i would try to find a close match for tires also its hard to find atv tires that are the same size and the price is twice than good AG tires cheers
8tyman8
Premium Member
sounds like you're about to have some fun oldbuzzard i'm loking for another one to start on made an offer on a g14 but no response yet so we'll wait something will come my way . have fun and a blessed evening in Christ
Good news it's off the trailer. Hope the back-up issue is the brake... that would be great!
I wholeheartedly agree with Alan. Sometimes, it's something simple. Not always, but sometimes. Good luck!
Deceased
8tyman8
I would take issue with the "price is twice than good AG tires".
The 26x12x12 CST Ancla ATV tires that I put on my 1886 cost me just under $200.00 delivered. A pair of Carlisle Tru Power tires from Miller tire would cost me $235.35 delivered.
I'm seriously considering Ancla's for the G11, but, the size that is closest to the stock G11 (23x8.25x12 would be 25x10x12. I haven't looked, but I'm thinking that those would clear the fenders with room to spare. Of course, I would increase the size of the front tires as well to make sure that the tractor was 'level'.
This tractor won't be used for much more than towing trailers, etc. If it IS used for anything other than that, it would be for mounted/standalone implements like the Chipper/Shredder, etc.
Glad to hear the transmission problem seems to be an easy fix. Tires are a major expense when you are restoring a GT. I don't think most people realize how expensive they are.
i put Carlisle at428 25x11x12 4 plys on my 12x7.5 rims and put the on my 1254 there tight but work how ever it was a pain in the arse the get the bead to seat proper you can get 25x8x12s for it
cheers
8tyman8
Deceased
Discussion Starter · #9 ·
Well, the REAR tire situation is taken care of for the time being at least.
Fella on CL had a pair of 23x9.50x12 tires and wheels listed for $30.00. Original size is 23x8.50x12 so 1" wider shouldn't really make a difference.
They are now sitting in the back of the pickup. If/when the danged rain quits I'll get them put on the tractor.
I'll probably put new tires on once it's restored but these will do until then.
Still debating on what to put on the front. I DO like the looks of the 5-ribbed V61s.
I think I would try and stick with original style tires and tread.
In my opinion a Bolens just dosen't look right with anything but the original size and tread.
The front and rear tires used on these were pretty common and it shouldnt be too hard to find a decent set of used ones to put on it.
Deceased
Discussion Starter · #11 ·
Put the 'new' used tires on the 11. They are just a stop gap, until I decide just what I really want.
Bought a new battery, and when I went to install it, found that the end of the Positive battery cable is gone. Guess I'm going to either fix this one of try to find a new one.Good news though is that the battery hold down clamp is there.
Also noticed that Ground cable is on the wrong side of the tractor. I'll have to move that as well.
While I had the right rear wheel off, I got the freewheeling pin out. Thing is it doesn't want to go back in.
I hit it with some sand paper, but that didn't help. I guess I'll have to get some emery cloth and see if I can polish it up enough to slide back in.
Deceased
Discussion Starter · #12 ·
Finally got a battery installed in the G11. Had to put a new end on the POS. cable. Still has the orig battery tie down so I used that as well.
I pulled the freewheeling pin from the 800 and put it in the G11, put it in neutral, turned the key, and .......silence
At first I was thinking, "Dang, electrical problems". Then I said to my self "Self, I wonder if the interlocks are still working?". So, I mashed down on the clutch/brake, and danged it it didn't start right up
Engine sounds GREAT, purrs like a big kitty. That's the GOOD news.
The not so bad news is that when I turned the key to off...it kept running, and I had to ground the plug to get it shut down. Still, that's going to be a lot easier fix than not starting
The BAD,BAD news is the reverse seems to be 'gone'. I had hoped that it was just a bad brake on the drive shaft, but with the engine stopped, the trans in reverse, then started, and trying to move, all it does is grind. Not a hard, loud grind, but almost like the old "playing card in the bicycle spokes" kind of grind, like it's just barely touching.
Guess I'm going to have to open it up and take a look. I hope that maybe it's a shift fork, but it shifts into 1st through 3rd, and runs just fine in those gears.
I also got a pair of 'new/used' front wheels for it. The old ones are junk. I have them and some new tires at the local mower shop.
Sure hope I don't have to go looking for a used trans.
1 - 13 of 13 Posts
