1 - 12 of 12 Posts
So I just did a gasket kit of my g12 as it was leaking some oil, I also did the head gasket but not the rings are it has decent compression.
I finally had time to put it back together today, and installed the mower deck.
Where trying to engage the deck the tractor falls flat on its face.
It also did this trying to take of in 2nd and 3rd high range.
I am suspecting the carb needs a rebuild, but I worry I may have not put the governor back properly, though I was confident I did.
Any suggestions? Thanks!
Find a troubleshooting guide in the engine manual. We have some good ones in the Manuals Section. I would check the spark, compression, and fuel systems in that order. Good Luck, Rick
My first tubeframe was a restored 800, everything had been done except for a carb rebuild and it behaved like you describe, once I engaged the mower deck it just died.
My carb was really plugged up, it would only idle with the choke partially engaged - after the the rebuild it ran fine.
Discussion Starter · #5 ·
I am going to try and clean a carb without damaging any gaskets today.
I did find a manual but nothing that pertains to lose of power under load.
Old, but not dead -- yet!
Before pulling the carb apart, you can try opening the main adjuster slightly to richen the mixture. ...The engine may be slightly rich under no load, but that is not a problem.
If you engage the deck quickly, or while moving, this often increases the load, and causes the engine to bog down or stall.
"Dumping the clutch" in high gear will often do the same thing.
Discussion Starter · #8 ·
It was running top notch before.
Got the carb cleaner, it helped. What are factor carb settings?
A Little Off Plumb
Here are the settings from the Tube Frame Manual
Discussion Starter · #10 ·
Thanks.
It is getting better, I can now engage mower but not engage mower and put it in gear.
A Little Off Plumb
1 - 12 of 12 Posts
