1 - 7 of 7 Posts
Went to mow yesterday and when I was filling up the Bolens I noticed gas started leaking from the carb. It wasn't doing this when I last used it about a week ago. I have never messed with a carburetor before so I have no idea where to start. Help!
Sent from my XT1585 using Tapatalk
^ What he said ^
The only cause of leaking gas i can think of is, sticking float/needle valve, or possibly a bad gasket. i would also say, maybe a warped top or bottom half of the carb, but if it happened all of a sudden, i wold rule that out. Your best bet is to clean the carb, make sure the float dosent stick, and the needle valve moves freely, and go fro there.
no cracks in fuel lines or loose clamps?
try some seafoam in the gas and also shooting some down the carb and around while it's running - may "loosen" up what's stuck or dislodge some "dirt"
Discussion Starter · #5 ·
Got it fellas, the needle valve was stuck. Had to take the fuel inlet Barb off to get to it. It's a Bolens 2028 with the 8 horse Briggs and Stratton.
Now, to diagnose why it's not starting. The other day it wouldn't start. Gas tank was low so figured it was that. Found my leak when I filled the tank.
Runs when I pour gas right in the carb it runs until that gas burns off.
Might have the needle valve stuck closed now and not letting the gas into the carb. It is kind of the nature of some of these old carbs to want to leak gas while sitting around. I try to remember to turn the gas off when I am finished for the day, but don't always work out that way and come back to a big wet spot and empty tank.
  • Like
Reactions: 637Yeoman
I'd start with chieffan's suggestion, but if you're satisfied that the needle isn't sticking, I'd pull the jets and clean them and the passages. Last winter my Husky 750 ran out of gas and some sediment from the past got stirred up and ended up clogging things up. Turned into on of those lessons about cleaning the entire fuel system the first time instead of doing it several times.
1 - 7 of 7 Posts
