Is it necessary to remove the gears and shafts on a 3 speed to renew the oil seal on the input shaft?
The Tube Frame manual implies i do not - It is installed post shaft but what about removal?
On the same line - Removing the transaxle - Aside from unbolting it from the actual tubes, It just requires the bolts removed from the coupling on the input shaft to be free?
