1 - 20 of 171 Posts
I picked this up on Wednesday! It's a little rough, needs all 4 tires. But it steers easily and the deck is free. I can just make out the model #'s. Looks like a 915 01. All I can make out on the serial is 062 toward the end of the tag. Cannot make out any of the deck #'s. Here's some pics.
Wheel Tire Motor vehicle Automotive tire Vehicle
Wheel Tire Vehicle registration plate Automotive tire Motor vehicle
Automotive tire Gas Motor vehicle Automotive wheel system Font
Tire Wheel Automotive tire Motor vehicle Vehicle
Motor vehicle Automotive tire Wood Automotive exterior Asphalt
Font Wood Gas Signage Soil
Green Motor vehicle Font Paint Gas
What engine is on this?
I have had some luck bringing back the numbers on the decals by wetting a finger or thumb with saliva and rubbing fairly firm on the white one pass then across the numbers. The chalking from the white will stay in the numbers enough to read them fairly good. Worth a try.
  • Like
Reactions: logmillingman
According to Bolens paperwork:
The 915-01 Lawn keeper was a 1968 model, and was equipped with a Tecumseh V60-70093D engine.
The 915-03 Lawn keeper was a 1969 & 1970 model, and was equipped with a Tecumseh V60-70166G engine.
There was no mention of a 915-02.
I can't swear by the #'s I posted, but thanks for the info. Kind of thought it was a Tecumseh!
Old, but not dead -- yet!
The Tecumseh engine numbers should be stamped into the sheet-metal shroud just above the 3 head bolts holding the shroud to the head.
If your engine is original, you may be able to identify the Bolens model by the Tecumseh number.
Discussion Starter · #11 ·
There is a plate (with #'s) on the side of the engine block. I'll get pics of it today!
Discussion Starter · #13 ·
I got pics of the plate on the engine!
Rectangle Wood Fixture Font Gas
Rectangle Fixture Font Gas Concrete
Looks like this is a 1968 model!
Discussion Starter · #14 ·
Can someone give me the paint colors for this? And are the wheels supposed to be White? I hope to get some tires for it soon and see if I can get it running!
What brand of paint are you planning on using? I have the Rustoleum X-O rust code for the yellow as well as the deck but nothing in automotive so far.
Wheels were white on tractor and deck
Discussion Starter · #17 ·
That would work.
Deceased
There cool little mowers I know they offered a snow plow but I don't see it good for that not like a Gk but there cool to mow with
  • Like
Reactions: KennyP
1 - 20 of 171 Posts
