1 - 10 of 10 Posts
Premium Member
I actually had it mounted up the other day but since I had trouble with the coil I didn't get a chance to get it out of the garage and test my top link shortening I did.
I purchased the plow at the Dover, PA show and did try to get it mounted at the show so we didn't have to carry it or pick it up but my top link was too long and I couldn't get the plow off the ground more then maybe a 1/2".
The original top link was messed up when I got this 3pt hitch which I robbed off of the Snapper 1655 I sold. I went to Tractor Supply and bought the smallest top link they had and it seemed like it was going to be alright. At least with the a-frame and sleeve hitch plow it did.
So this past week I took the top link off and basically cut an inch out of each end and welded it back together. I need to primer and paint it yet but I think I have it at the right length now and it is only about a 1/2" longer then what the original one was.
I told dad that I can't wait to bury the plow in the ground and he said about before too long we will be able to. Not even 10 minutes later I went to hop on the tractor to pull it in the garage. Lifted the front end loader but forgot the plow was back there which I had in the down position and almost started going before I realized it was down LOL.
Here are the pics:
Looks like a good sized plow. I have a 10"? I think for my SS16 Sears and it pulls it good. I'm sure the 12" will be no problem for the 1655. Going to drive away with a 3pt implement down isn't half as bad as going to walk around the back of the tractor and forgetting that it's there. LOL
Looking great George! You coulda really messed up the driveway with that monster LOL! Can't wait to see some pics of the beast turning some dirt!
That should tear up some dirt George. Looks good on the 1655.
Premium Member
Discussion Starter · #7 ·
IamSherwood said:
Lookin George.
Those tires loaded?
The tires aren't loaded yet. I have fluid waiting to be put in them, just didn't have time to do it yet.
Looks good! Could use a little paint on it though.:bigrofl:
Premium Member
Discussion Starter · #9 ·
Yes it does need painted. Once I get the Cub 122 repainted and back together I would like to strip the plow and have it all purdied up for plow day.
Told you at Dover I'd post something soon, now here's my chance. I remember seeing that plow and thinking it was a decent price. Now, when you paint it up there's a trick you can perform on the rusty plow bottom to save a lot of work getting it shiny (scoured). Get a quart of graphite paint. (John Deere dealers carry it, used to be "slip plate," but now they dropped that name) I think TSC also has it. Anyway, just do a light wire brush job on the share and moldboard to knock off the loose rust. Then brush on 2 coats of the graphite paint. Once you drop the plow in the ground, it will not stick and the soil will wear the paint and rust off at the same time from the bottom up. I've done this a few times and it works great.
1 - 10 of 10 Posts
