1 - 6 of 6 Posts
I was using my MF14 and pulled up to the house when it suddenly revved way up and died. Tried to restart it but no go. Anyone have any ideas so I don't go around chasing my tail? Think I'll get a head gasket, points and plug, decarbonize it, and install points and plug. What else?????
On another note, GET READY FOR SPRING!! The last 3 days I've heard geese flying over headed north and the peach and plum trees are in bloom.
Take a very close look at the governor components on the outside of the motor, then at the carb butterfly. See if anything is loose or missing. (like a butterfly screw) You might of had something come apart on the governor inside the motor block too.
If these all look good, try hitting the carb with a shot of carb cleaner or starting fluid into the inlet and see it it will fire. Also check for spark and compression. (Just a finger test over the plug hole will do)
Ronnie, start with the basics. 1st Does the engine still have compression? Then check the spark. It should jump 3/16" at least. Revving up could have been leaning out and running out of fuel. Spray a little brake or carb clean in the hole and see if it will fire. (make sure your using the flammable kind). Changing the plug is a quick test and you can test most of the other things at the same time. I would do some diagnosing first before I started changing too many parts and tearing down.
Premium Member
Like Doug mentioned about the revving up, usually means it went lean for some reason. First check and make sure you have gas, and also check and make sure gas is getting to the carb.
Electric Tractors
Sounds like it started to run lean then die, or the throttle plate came off and got sucked in till it died.
Either way it's carburetor problem, wouldn't hurt to pull it off and start there, at least give it a good cleaning.
Hey tinnern, When I bought my MF14 many years ago it wasn't running and the problem was, as mentioned above, the screw in the carb butterfly. I was unable to find a screw with matching threads so I ended up tapping the shaft and putting in another screw. If the screw did come out you know where it went! Good luck with it.
1 - 6 of 6 Posts
