1 - 13 of 13 Posts
Happy Sunday to everyone .Its a beautiful day ( maybe one of the last ones of the year ) and I should be out side playing on my tractor , but I can't .... I broke it :(
Maybe someone here can walk me thro. a diagnosis . it has a FEL but Im not sure who made it . The controller has " gresen 2702 " stamped on it . THe only thing I can make out on the pump is " M9 - "
The issue is , the bucket will not lift unless I squeeze the return line - and even then its real jerky . It does not sink down , it will hold its postion for days without dropping . Can anyone help point this noob in the right direction please.
Thank you
J.T.M.
Discussion Starter · #3 ·
Thanks for the reply and the welcome Doug .... Yes first thing I checked . With me , not being much of a mechanic , You would not believe how badly I wanted that to be the issue .But no , it was full :(
the homeless tractor hoarder
I'm not much on hydraulic issues but it sounds like the fluid is not being diverted to the lift cylinders when the lever is pulled. Its just bypassing back to the reservoir. ???
Welcome to GTT. That is a fine machine you have. I would guess that your control valve has worn out or ripped an o ring or the safety( pressure by pass) is stuck open. Check our Manuals Section for 3 free downloads per day. I will look too. Good Luck, Rick
Try this manual: http://gardentractortalk.com/forums/files/file/2617-brantly-loaders-owners-manual/ it has hydraulic diagrams that are fairly universal.
Discussion Starter · #6 ·
After doing a search I have come to the conclusion that the fel is a Johnson model 10 .
Its not even making it back to the reservoir ( unless I pinch off the line ) .
I hope that your right and it truns out to be a fine machine .I only got to drive it about 30 mins. after buying it ( i'm certain I way over paid ) and getting it home before it broke . Wife is giving me that stink eye look ... :(
We've all been there. Look at my revised post before and I will find what I can on the Johnson 10. You have one of the great Large Frame Bolens I have 3 and they are my favorite out of 85 tractors. As you can, download all for the pertainent manuals. Good Luck, Rick
Here is for Johnson 10 http://gardentractortalk.com/forums/files/file/4229-johnson-work-horse-loader-midget-model-10-for-bolens-800-900-1000/
The valve should be a simple rebuild or replacement from Burdens Surplus Center.
Welcome to GTTalk ! You said the bucket won't lift , does the bucket tilt correctly ? If so and if there's enough slack in the hoses you could try swapping the lines between to bucket tilt and loader arms at the control valve . That might give you some clues
  • Like
Reactions: J.T.M.
Discussion Starter · #12 ·
Greetings Alc . and good morning .
Neither the bucket tilt or the boom raising will work correctly . Im off to work and would like to thank all for their input .
old member
My friend has a Johnson 10 on a 1476 and he had trouble with the pump suction line collapsing that caused a similar problem. He put a piece of flexible conduit in it and it was fixed.
1 - 13 of 13 Posts
