1 - 4 of 4 Posts
Hello everyone
I've a H16 with a mower deck. I've attached the deck to the mounting points and it runs and cuts well (rebuilt). I see no way to use the hydraulic lift with the hardware I have to lift the deck so, it runs on the wheel height. Could someone take a picture of the hydraulic side and the other side and post for me?
Thank's in advance
Thomas
Check the manuals section for the manual for your particular deck. It should show the hydraulic lift hook up.
Discussion Starter · #3 ·
Chef
Looked into the parts list and installation guide. All of the decks are similar but not exact, so, I can't quite tell whats what.
Thank's,
Thomas
I had problems figuring mine out because mine was hacked using the loop for the G series. If you look at my pics you can see where I removed the loop & replaced it with a piece of flat stock. If you could give us a few pics of yours we can help you figure out what is wrong.
1 - 4 of 4 Posts
