1 - 14 of 14 Posts
Hello. Ok this is what we where lead to believe is an Ht 23. It has a 22 horse mot
or. 12x26 rear tires.cant read ident tag. Front hydraulic and rear with a three point hitch. Posting pic of trans first. More to follow. It doesn't look like a Eaton 11.
Hello, and welcome to the group! What part of Michigan?
Paul
  • Like
Reactions: 637Yeoman and Bgun
Got Sum
Welcome to GTtalk, that's a Sundstrand 15 hydro pump, so it's probably not HT23 unless some one swapped the whole rear end out. The 23 has a two speed (hi-lo) rear end, could be an HT18 or 20, does that model number tag end in 05? An 1886 -05 ,06 has a Sundstrand pump also, I can't make out the rest of the number on the tag, looks like 1886 . If so it's an 18hp (if original) engine.Your Hydro is missing the charge pump off the front of it, if you didn't remove it.
Premium Member
Can you take more photos of the tractor like the other side of the dash tower?
It is a 1886s-05 or 1886s-06. Mostly the same tractor just different paint jobs. Can you work on the tag a little more maybe the number will show.
Discussion Starter · #10 ·
It is an 1886 05 but I can't find any cream colored paint.just white.green.black. and the red that is on it.
Premium Member
Did you get the tag so you could read it to find a 5?
Premium Member
Cool happy you could get to read it. I was thinking it was a 1886s-05 by the modal tag anyways. Bolens changed the ID tags on the 1886s-06.
Need anything else just ask.
  • Like
Reactions: Bgun
1 - 14 of 14 Posts
