1 - 3 of 3 Posts
I bought a mf12g in a garage sale a couple months ago and a week before it snows, it nuked the connecting rod. i need to know the engine specs so i can measure and make sure the crank and block can be still used, and order parts if everything checks out ok.
Please help if you can
Thanks Nik
niksdaytona:welcometogttalk:glad to have you with us.
That would be a Tecumseh right ?
This is from tractordata.com,I don't know if it will help.
Engine:
Manufacturer: Tecumseh
Model: HH120
Fuel: gasoline
Cylinders: 1
Valves: -unknown-
Bore/Stroke: 3.5x2.875 inches [89 x 73 mm]
Displacement: 27.7 ci [0.5 L]
Power: 12 hp [8.9 kW]
Cooling: air
Compression: -unknown-
Rated RPMs: 3600
Starter type: -unknown-
1 - 3 of 3 Posts
