1 - 14 of 14 Posts
I recently got a massey 10 and from the get go its had carb problems it will only run with choke on half way if choke is off if spits and spuds and dies. I took its apart cleaned it all out with cleaner. Put back together adjusted it. cleaned tank filled back with clean gas pored some sea foam in tank.got it to run decent enough to mow my yard. It's been parked for a week got on it today started fine mowed about ten min and it started back to spitting and spuddering again. I'm thinking I might can get by with just a carb rebuild kit. Or do you all think it needs a hole new carb? Also while I had it running good before it acted up this last time. When it's running its either wide open or idle. Your can ease the throttle up but it will go wide open.while throttle is half way up. Is that just the way it is with these motors or........help please. I hope I put this post in the right place I'm a newbie on this site sorry if its wrong.
Fixer of Broken junk
Sounds like your governor needs to be reset 1st off.
Do not blow out the fuel inlet unless you want the little rubber needle valve seat to fly out.You'll never find it if it does fly out.Make sure that your float doesn't have a hole in it.Easy to check,just shake it,if it's sounds like there's fuel in it then it's shot.
Set your float correctly.
Make sure that you take out the low speed needle and clean out Both the Primary and secondary Idle discharge jets.They are commonly overlooked.
Here's a good little manual for the Tecumseh LME carbs. Pages 8-14 And governor adjustments on pages 18-20
http://gardentractortalk.com/forums/files/file/1586-tecumseh-cast-iron-8-to-18hp-engine-manual/
I just got my Sears custom 10xl running perfectly with just a heck of a good cleaning.HH100 with LME carb.Torch tip cleaner tool works beautifully for cleaning jets.Take your time and clean Everything.You can't rush a good cleaning.If you do you'll have to take it back apart later and do it again.
Make it spotless and it will run.
http://pwp.bellsouth.net/t/h/the3hares/pdfs/Tecumseh_Cast-Iron_Engines_Service_Information.pdf
Nice info Eric...Thanks!
  • Like
Reactions: Kyburley
Tecumseh carbs are very very picky about even the slightest bit of dust,dirt,hair or even that little bit of white glazing you get from it not being cleaned in a while.
I've used many chemicals in the past to clean a carb but None even come close to a good old fashioned manual cleaning.Small wire tube brush kit and a torch tip cleaner kit and about 1-2 hours of your time and it will be like new.
Here's what I use.
!CDgWP-g!mk~$(KGrHqIOKnUEz1)bkvt)BNO0,S5
$(KGrHqVHJFQFHZM7fTljBR4pzfUw,!~~60_57.J
I did have luck cooking a couple in an oven with spray on oven cleaner.But you really have to watch that you don't ruin the carb.Some oven cleaner is very acidic.
As Eric said, get the float set correctly. Very critical too. I've had 3 or 4 that
acted strange, until set exactly as spec'd. I believe it's 11/64" gap. A 32nd
in either direction, will make a difference. Also, make sure the 2 gaskets at the
mount are good, and that the flange ears haven't been bent. Sucking air there
is also a possible reason for it to act up.
Good info in the above posts. Although I have a Sears, it is still a Tecumseh HH100 and the same types of problems. I haven't got all the bugs worked out with my carb yet but when I have some spare cash to spend, I plan on taking it back off and replacing the throttle shaft and maybe a service jet all at once. Right now, it is running well enough to work.
Keep us posted on your progress with this problem. It could help me and others too, I am sure.
Discussion Starter · #10 ·
thanks for all the help guys. i stripped the carb all the way down there was more dirt nothing real bad but i took my sweet TIME and cleaned with carb cleaner and brushes and torch tip cleaners i replaced the inline fliter put on new gaskets and set the float gap according to manual.also found that the letters stamped on the choke flap were turned around backwards letters were faceing towards inside of carb.i never touched that before just happen to notice it was wrong acording to the manual so i put back the way it needs to be witch might not even matter.i reset the govner to factory specs,put on new spark plug new battery old one wouldnt take a charge.hit the key never choked and she fired up and pured like a kitten.the throttle now works as it should.(move throttle up a little motor revs alittle higher) i mowed hole yard and never missed a lick runs as it should, once agian a great big thanks for all the tips for each and everyone of you wonderfull fellers!!! i will try to post a few pick of the tear down if computer will act right
Great news. Glad you got it dialed in.
Good catch on the choke plate. I'm not sure what difference that makes, as I've never
paid attention to that, but it must be done like that for a reason.
Happy mowing. :thumbs:
Looking forward to the pics.
Glad that you got it running. Be careful when removing the nozzle on these Walbro LME carburetors. The factory original nozzles were inserted into the carburetor body and then drilled out. The replacement nozzles have annular rings machined in them with many holes drilled so that one will align when reinserted. Reinserting the factory original and getting the carburetor body hole to line up with the nozzle's is just random chance. Unfortunately there are no longer replacement nozzles available for most of the older Walbros including the one's in HH100's and HH120's. So without knowing whether the carburetor has the original or a replacement already, nozzle removal might be risky.
1 - 14 of 14 Posts
