1 - 4 of 4 Posts
Have G14, want to look at my G9 parts chassis and see if same clutch parts. I see a coupler offered on epay that says G9 and looks like a keyed one to axle, not splined like mine. Splined one for G14 also offered but pricey! SO, I looked at 1053 model parts book here and has same part numbers as my G14, but that might be bigger tractor again? What are the numbers for the G9, don't see that G9 listed on the manuals as that like the others. I wan'ted to look at a parts book for it, not sure what one is right or even if one on the forum is what I"M saying. All these model names being mixed up in two ways gets me mixed up. I don't have the parts rig home yet to look at it.
Deceased
Since you can't find a G9 parts manual, try using the G10 manual.
The G9 should be pretty much identical to the G10 with the exception of the engine.
The G9,10, and 11 have a different setup than the G14. They use an idler against the drive belt as opposed to a true clutch.
Discussion Starter · #3 ·
OK, just my luck they are diff. SO, on those G10 and others, they don't list that way. Using the model is 10** or similar than? So, how do I connect the four digit number to be the right G model? See, that is where I get lost.
Deceased
G9 - 855
G9 - 1055
G11 -1155
G12- 1255
G-14- 1453
By 'rights' the G9 should really have been the G8, but for one reason or another Bolens used the G8 designation for the 813 Small (stamped) Frame tractor,
1 - 4 of 4 Posts
