1 - 11 of 11 Posts
Has anyone found a source for an exact match piano hinge for the hood/grill?
Quite often, only one leaf of the hinge is damaged, and rather than replace
the entire hinge, it would be so much easier to just replace the broken pc.
The hinge is 1.5" wide when open, .090" thick material, .125 pin dia., and
the knuckle length is 1"
I have some hinge out in the garage that may fit to those dimensions. I'll see if I can get it measured today!
  • Like
Reactions: IamSherwood
Discussion Starter · #3 ·
I've checked the McMaster Carr site. No luck. Also checked with
a large Canadian supplier of specialty stuff like that, Spae Naur , with no luck.
The only thing I am seeing different may be the pin dia. But I'll post the size of this hinge just in case. If it will work, you are welcome to a section of it for your purpose.
Mine is different! 2" wide, .060" thick, .125" pin, & 1/2" knuckle! Sorry!
  • Like
Thanks Alan.
I've got to re-measure the OE ones. 90 thou seems kinda thick.
Maybe if I scratch the paint off, I can get it down to 60 thou.
Stainless would be useable, even if I can't weld it, and if it's a bit
weaker than steel, it would still beat removing the spot welded pc
off the headlight panel.
Cool!
1 - 11 of 11 Posts
