1 - 10 of 10 Posts
Nut Case
I have both a 14 and a 16 that have hoods in dire need of repairs. I'm gonna try my hand at one. The thing that worries me is getting the headlight panel back in the right spot for the bezel to bolt on correctly. Can someone post a pic of a good hood with a tape measure from the face of the headlight panel to the edge of the metal so I know where to attach things back in correctly? Thanks.
Eric
  • Like
Reactions: Gabriel
Do you mean the flat panel with the 2 holes for the lights? It must be smashed up pretty bad if that's come apart. I have an 8 hood that I can take photos of. It's all assembled with headlights installed. I just haven't put it back on the tractor. Do you know if the 8 hood is the same as the 14,16? The width may be the same but I'm pretty sure it's shorter.
Nut Case
Discussion Starter · #3 ·
Yes, one is almost tore in half and the other has the top 2 welds broke. They need straightened and reinforced. I just want to make sure they are lined up correctly after repairs. If the 8 takes the same bezel then it would work. Thanks.
Eric
  • Like
Reactions: IamSherwood
Oh man, I was going to measure one today, but forgot. (age===darn)
They do take the same bezel, so if Brian has one handy, that would give you
the measurement you need. I'm writing myself a note right now, and will measure
a 14 hood tomorrow, just in case.
Nut Case
Discussion Starter · #5 ·
I'm not in that much of a hurry. When I get the picture means I have to go get to work on them. Its cold haha.
Eric
  • Like
I checked 3 different ones. They're all a bit bent, but on the sides where
the headlight plate is spot welded to the hood I get the same measurement
of 7/16" from the headlight plate to the edge of the hood. The crease for the bottom
lip that the hinge bolts to, appears to be in line with the front edge of the hood at the bottom.
Do you have the bezel? If so, you could make sure of the location by just putting it in place and
scribing the inside of the hood.
Hope this helps.
Nut Case
Discussion Starter · #8 ·
I have one good bezel that I can use but that measurement gives me something to look for. The hood on the 16 is almost off. It also doesn't line up right with the dash because of the hinge and headlight panel being bent and weak. You can't open the hood and leave it up. The cable is in place but the headlight panel is tore to where it will not support the hood anymore. Thanks again.
Eric
  • Like
Reactions: Sawdust
I've been busy and didin't get the pictures yet. Mine was bent when I got it. I would straighten out the front hood baffle( the piece that the bezel bolts too), bolt your good bezel to it and tape the assembly to the hood. That should get you where you need to be. Are the 2 metal clips still on the underside of the hood.
Just took some shots but I'm not sure they will help. Hood is assembled with insulation etc. In the first picture 3rd row down you can see the 2 metal clips I'm talking about. My hood was bent a bit and I didn't end up with a perfect fit between the shape of the hood and the bezel. If you are able to mount the bezel to a baffle then fit that to the hood you should end up with a really close fit.
Vehicle Motor vehicle Automotive lighting Classic car Electronic instrument Automotive parking light Automotive tail & brake light Grille Motor vehicle Automotive lighting
Automotive tire Road surface Asphalt Automotive lighting Motor vehicle Automotive lighting Automotive tire Motor vehicle Bumper Rim
Hood Automotive lighting Amber Wood Rectangle Hood Vehicle Automotive lighting Motor vehicle Automotive design
Automotive lighting Bumper Wood Motor vehicle Automotive exterior Hood Vehicle Motor vehicle Automotive design Bumper
Luggage and bags Automotive lighting Trunk Motor vehicle Bag
I said this in my post above:
Scrap that. I took a better look at my pictures after seeing Brian's. If it gets welded in that way, the
headlights will be aimed at the neighbours upstairs bedroom windows, and you'll probably get a visit
from the police for peeping.
1 - 10 of 10 Posts
