I have a White GT1855 with wheel weights and tire chains. I use a 45" snowthrower. The thing just has little traction in the snow. It has a three point hitch. How can I add additional weight to the rear?
Thanks
Thanks
I used antifreeze to fill mine. A 23x10.50x12 will hold about 6 gal. Some have used windshield washer fluid. I used antifreeze because it was free. I made my filler from an old gallon jug, about 3' of 1/4" cleàr plastic hose and a nylon Barb fitting (the hose and fitting was like $3 at Lowes). I drilled the cap and threaded the fitting in it. Cut the bottom Out of the jug and thread the cap back on. That's your funnel. Attach it to your bench or something like that. Take the valve core out of your tire and lay it on the floor. The tubing fits snugly over your valve stem. Takes a while due to you have to allow the air to burp out as the fluid goes in.How does one fill the tires and with what?
Thanks
Fastest and best way I have used is to remove the wheel and lay them on the floor with a 2X4 under one side. Break the bead loose from the rim in one place only. Stick a large screwdriver between the tire and rim and start pouring. I use RV Antifreeze. Pour it as full as you can get it, remove the screwdriver and put the air back in. Remember you will only have a very small cavity to fill with air so don't over do it. This method is much faster than going thought the valve steam and burping it all the time. Just my way to do it. Fast and simple.How does one fill the tires and with what?
Thanks
That works great if you don't have tubes to fill.Fastest and best way I have used is to remove the wheel and lay them on the floor with a 2X4 under one side. Break the bead loose from the rim in one place only. Stick a large screwdriver between the tire and rim and start pouring. I use RV Antifreeze. Pour it as full as you can get it, remove the screwdriver and put the air back in. Remember you will only have a very small cavity to fill with air so don't over do it. This method is much faster than going thought the valve steam and burping it all the time. Just my way to do it. Fast and simple.
Hey I ain't that fat. (looks in mirror) Um ok.If you add a seat to your three point hitch, Uncle Willie would be happy riding with you.
It looks like muscle to me,which is an extra advantage if he gets stuck.Hey I ain't that fat. (looks in mirror) Um ok.
That's one of the downsides to using the 3-pt or other method to hang weight on the rear of the tractor. The other is added stress on the rear axle.... Too much weight and you will make the front end light and have trouble getting traction for steering. ...
