I’ve been having some overheating issues with my 782 in the summer heat. I built a muffler shroud out of roof flashing, and it was a huge improvement.
Not pretty but it does the job.
After a lot of mowing in the sun, the hood is slightly hot (very warm), the side panels (front part near exhaust) gets too hot to keep your hand on it for more than 5 seconds. The frame for the front grille or the front end part gets too hot for 3 seconds. It’s not to burn level, but discomfort level. How hot can this paint get while being un-effected? Thanks. I’ll get a temp gun and get a proper reading eventually.
Don't think you will see it burn unless the muffler is right on it.
But just with the high heat you will see it discolor after a while. Probably turn coffee brown looking..
I had the same concern with the custom muffler on my roper 20T. I ordered a roll of adhesive backed heat shield from Summit Racing. Seems to work good. I think this stuff is used on the fire wall around the drivers feet.
Well I just called rustoleum customer service. Apparently my paint can tolerate 200 degrees Fahrenheit before any bubbling or damage can occur. And they also told me the paint will not discolor or fade with that heat unless it is at or above 200 degrees. I don’t think even the hottest part gets that hot. So I think that’s something to consider.
I painted the inside of my hood with rustoleum mixed with Thermacell ceramic microsphere insulation beads. It seems to work well and not subject to damage. It does leave a bit of a sandpaper feel in the paint, but it's the inside of the hood. Obviously, I used brush on paint, not spray paint to mix the beads in. I finished with a spray on color coat.
UPDATE: Just worked the tractor in the summer heat (88 degrees). And when the tractor was hot as I could get it, I took temperatures with a temp gun. Paint can safely and reliably go up to 200 degrees, and the hottest part of the paint got to 140 F. You can see the exhaust pipe is at 237 F. That shield works GREAT 👍
