Had a problem with the lgt165 ford today. I heard a snap and It stopped lifting the blower. Into the shop, figured out what was wrong, difficult place to work, figugued out how to fix it, found the stuff to do it, needed to make a 3/8 hole in 1/4 plate where the stud that lifts every thing was. When the stud broke out, if left a small hole throught the plate. So only need a bit more to enlarge it to get the 3/8 bolt in. Difficult place to work, so tried to figure away to drill it. Then thought, I'll use the cutting torch to cut it out, only needed a little bit. So lit the torch, put it up to cut , then instantly the old,oil and grease filled, grass went afire. Tried to blow it out, that was stupid, so it was heading to the plastic gas tank 1/3 full of gas. So ran outside , got some snow and threw it on it. Then crawled under and dug out the rest of the grass on fire and got it out. Burnt two wires. All the time this was happening I was in panic mode and wondered how long do I stay in here before the gas tank melts. And thinking about losing three tractors, my sons 64 rambler , my fathers tools and all the other stuff I have collected.
So please be carefully in your shops.
As olcowhand said, I'll go hide in my corner now. Noel
