It's been a while since I have had time to do anything with the Mutt [ Muttely]. Sometimes life has other plans and projects like this are off the stove, not even on a back burner. Today ended up being thunderstorms late morning, early afternoon so I decided to putter a bit. Back a few days ago while rearranging some clutter in my barn I stumbled onto a box filled with miscellaneous Bolens tube frame parts. I suspect that they were removed from my 1220 tractor when I tore it down to start a refurbish project back several years ago. There was a mangled light switch, amp gauge with a broken glass, an extremely grubby, corroded ignition switch, handful of rusty screws, bolts. And low and behold two red pull knob control cables, choke and throttle. Wow! I wish I had known they were there a couple months ago when I started working on the Mutt. Actually, this is funny but sad too. I have "useful things for possible future use" [junk] squirreled away and don't remember all of it or exactly where I put at the time. I am working on that problem and have made much progress on sorting out the true junk that gets tossed and the pieces that are worthy of being organized and shelved. Quite a process! So back to my project today. I found the throttle control cable was going to be good fit. Gave it bit of a clean-up and a generous oiling then installed it in place of the generic cable I initially used. Works good and now I can set and twist-loc it at whatever engine speed is desired. Great! Next, I decided to adjust the tie rod as I could visibly see that the front wheels were toed-in quite a bit. My tape measure confirmed that there was about 3/4" toe-in. That happened at some point before I took possession of the tractor. I'd never tinkered with any of the steering components other that greasing and oiling. So, a bit of trial and error and I have just a smidge of toe-in. maybe 1/8" give or take a hair. There is a small bit of wiggle in the fit of the axle to the spindles, so I'm saying this is good enough. It looks better now too. I did manage to find a pair of scarred but useable dust-caps that I figured ought to finish the new tire, correct wheels project. Nope, dust caps don't fit the hubs. The OD of the hubs is approx. 1 5/8" and the ID of the caps is approx. 1 1/2", with the OD being just about 1 5/8", same as the hub I want to fit them over. Ain't gonna fit! This is a puzzler to me. I maybe had a pair of front wheels at some point with a smaller diameter hub? If so, a pair of larger ID dust-caps wouldn't have fit on them. Dunno. At this point of my cleaning and rearranging mission I'm 99% sure there are no other dust-caps stashed anywhere. Throughout my tube frame tractor projects there should have always been an equal number of caps and wheels that fit each other. How this played out is beyond me. Another mystery here in GT Land!
